In-dash Nav Quick Question
Old Dec 4, 2011 | 12:19 AM
padlock's Avatar
where do you guys find it best to run your gps antenna? ill be installing my nav tomorrow, just curious as to where you found out to be the best spot
Old Dec 4, 2011 | 12:27 AM
EmperorJJ1's Avatar
outside of the vehicle. on the trunk lid is the easiest to hide in most cases
Old Dec 4, 2011 | 12:45 AM
padlock's Avatar
that seems like it would require a pretty long antenna cord. Im not sure if mine would even reach that far.
Old Dec 4, 2011 | 12:59 AM
EmperorJJ1's Avatar
ya it requires a long one. it shoudl come with one long enough but then again alot of companies have been slacking off
Old Dec 4, 2011 | 01:15 AM
b00sted06ss's Avatar
I always had the idea of putting the nav antenna in place of the factory xm antenna on mine, but do base models have those? I always thought that would be a clean look!
Old Dec 4, 2011 | 01:18 AM
padlock's Avatar
yea i have the xm antenna. i dont think all base models do though, just the ones with xm obviously
Old Dec 4, 2011 | 01:20 AM
I wonder if that could be a possible mounting spot? I just have no use for it since i don't have xm
Old Dec 4, 2011 | 01:23 AM
TommyP's Avatar
AWD > FWD
I actually kept mine inside the dash and never had a problem
Old Dec 4, 2011 | 01:24 AM
padlock's Avatar
i think it would be more of a pain in the ass then its worth to be truthful
as in you just crammed everything back in the dash without running it anywhere? that thought came to my mind too..
Old Dec 4, 2011 | 01:27 AM
TommyP's Avatar
AWD > FWD
Well since it attached by a magnet a stuck it to one of the metal supports near the top of the dash, but ya basically, made it much simpler and easier to install
Old Dec 4, 2011 | 01:30 AM
EmperorJJ1's Avatar
all that work and now the car is gone
padlock's Avatar
yea mine is a magnet too.. I believe i remember seeing you had a pioneer and so do i so i probably have the same magnet gps antenna dealio going on. sticking the magnet to the metal was my first option i thought of. glad to hear it worked good. Ill probably go that route
Old Dec 4, 2011 | 01:33 AM
EmperorJJ1's Avatar
if that is on the outside of the vehicle make sure to attach 3m tape unless u want it to **** up ur paint
Old Dec 4, 2011 | 01:40 AM
padlock's Avatar
no we were talking about just having it deep buried in the dash.. apparently that works just fine by attaching it to some of the metal cross beams in there
Old Dec 4, 2011 | 01:42 AM
EmperorJJ1's Avatar
depends it might might not. ive done it before and if im lazy ive done it in sight on the dash too. just depends on ur location
Old Dec 4, 2011 | 02:02 AM
gdubs's Avatar
I took my dash apart and have it sitting right next to the defrost vent
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
