Demon Eye Mod Question
Old May 13, 2012 | 03:52 AM
LtDanBoostdG5GT's Avatar
I have already done my demon Eye mod in my projectors..... I also have HIDs in these projectors.... the problem I have been having is that the LEDs sometimes melt....
What I want to do is I want my demon eye mod to be on when low beams are off... and on when I am running just drls/foglights in the daytime without low beams, and I want them on when I turn on my highs.. again without my lows.....
So Pretty Much the only time I want the demon eyes to run is when the lows are not on at all...
Let me know if you know how to do it... let alone if its even possible haha
Thanks
Old May 13, 2012 | 04:04 AM
SunburstSS's Avatar
Definatley possible, done it for a friend You can hook up a relay harness to both ur demon eyes lights and wire that relay to the low beams wires however u are using the port that will turn the bulbs on only the low beams are off " so when the relay doesn't detect positve voltage it will turn the power on for the demon eyes". Now as for the power wire you want to wire that to you drls or if u want to get fancy with it, wire it to a relay harness that activates when ur drls are on or foglights are on or whichever light u want to work with..
Old May 13, 2012 | 08:28 AM
TommyP's Avatar
AWD > FWD
would be easiest to wire them to a switch and just turn them on manually.
Old May 13, 2012 | 12:11 PM
C_A_D88's Avatar
^ lol
Old May 13, 2012 | 12:17 PM
MastaShaKe_88's Avatar
well if you got a 05-07 you can wire em to your dlr wire.. it ran off low input to the highbeams an then it would always be on.. unless you turn it off, or you turn your lights on
Old May 13, 2012 | 10:11 PM
SunburstSS.... would you be able to give me a how to for this.... lol
Old May 13, 2012 | 11:33 PM
Sox-Fan's Avatar
Got Brakes?
screw the LED, they are a pain. Paint the shield thing inside the projector red. Then when your headlights are off the shield reflects in there and makes the projector lens look red.
Old May 14, 2012 | 03:25 AM
EmperorJJ1's Avatar
lol that sounds ghetto but a better idea then leds... props if it works
Old May 14, 2012 | 06:52 AM
C_A_D88's Avatar
It does sorta kinda work
Old May 14, 2012 | 06:59 AM
C_A_D88's Avatar
Black painted shield
Green shield
Stock
Old May 14, 2012 | 08:57 PM
Sox-Fan's Avatar
Got Brakes?
I've seen it down with red, too.
Old May 15, 2012 | 01:33 AM
EmperorJJ1's Avatar
i might try that if i ever do my gen 1 retrofit
Old May 15, 2012 | 02:04 PM
brickloaf's Avatar
hes right...this is by far the easiest way to do it. but i'd just say **** the LED's and put in CCFL's cause LED's are not bright enough and they burn out like its their job
Old May 15, 2012 | 02:14 PM
C_A_D88's Avatar
It doesn't work as well as LEDs tho the painted shield only works If your looking at um the right way, but the black def helped to black out the projector lens in my blacked out projectors
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
