DIC panel trouble
Old Nov 16, 2006 | 08:11 AM
hardtocope's Avatar
DIC panel trouble
I've been trying to take off my DIC panel so i can take my radio out.. Can anyone help me out with this panel? I can't seem to find any tools to get it off without scratching anything up. How did everyone else get that panel off?
Old Nov 16, 2006 | 08:12 AM
xspyder85x's Avatar
what panel? the one that says the temp and all?
Old Nov 16, 2006 | 08:17 AM
BlilBT's Avatar
Get behind it with a small Flat Head, Then pull Hard But Gentlly! They are just Clips!
Old Nov 16, 2006 | 08:27 AM
hardtocope's Avatar
the panel that has the two buttons for the DIC. You can't just but a flat head behind it without scraping or denting something up. I have to first take off the one clip under the panel under the dash to beable to get a grip on the DIC panel but i can't even take that one clip because everything is so crowed.
Old Nov 16, 2006 | 08:43 AM
hardtocope's Avatar
is there a special tool i can buy for this?
Old Nov 16, 2006 | 11:17 AM
SilverTurboRidin's Avatar
dude. Dont be a bitch just take it out with a flat head. I did it to my moms car when i installed the sony head unit. YOU WONT BREAK ANYTHING JUST BE CAREFUL
Old Nov 16, 2006 | 11:21 AM
D4u2s0t's Avatar
if you pull off that large pice of plastic under the steering wheel, you will have easy access to the clips... you HAVE to take this off before you take of the DIC panel... just grab it at the bottom (slightly to the left of the shifter, just grab the bottom and pull) and it will snap out... the dic pannel has 2 clips, on on the bottom right, and one on the upper left... be careful, because the wires are not that long on this one, you don't want to rip the wires out...
if you get a flat head under the first clip that's on the bottom right, you should be able to tug it away enough to see the clip on the top left...
Old Nov 16, 2006 | 11:22 AM
R33P3R007's Avatar
360 L337 User
lorena bobbit.
Old Nov 16, 2006 | 11:25 AM
D4u2s0t's Avatar
pics to follow
Old Nov 16, 2006 | 11:37 AM
D4u2s0t's Avatar
ok, so here's the part you pull off to show the first clip. Just pull, its sturdy, you can't break it if you wanted to. I'm holding it at the top, but you want to pull it off from the bottom
Next, get a flathead and pry out the clip... my finger is the exact location... get the flathead ON the clip, and you don't have to worry about damaging anything... may be a little tough to get out
after that, you should be able to get enough clearance to get the top right clip, which is again by my finger
Old Nov 16, 2006 | 11:42 AM
R33P3R007's Avatar
360 L337 User
Originally Posted by R33P3R007
lorena bobbit.
you cant say i'm the only one that sees this as a bit humorous
Old Nov 16, 2006 | 11:45 AM
D4u2s0t's Avatar
haha... i didn't catch that onE!!
Old Nov 16, 2006 | 11:48 AM
splink's Avatar
thats the first thing i thought of when i read the thread
Old Nov 16, 2006 | 11:50 AM
hardtocope's Avatar
alright thanks for the pictures and the help. is there any wires conected to the panel under the steering that i have to worry about?
Old Nov 16, 2006 | 11:53 AM
D4u2s0t's Avatar
you're welcome... there's one on the bottom left, but it shouldn't be a problem...it's for the trunk release that's in that little pull-out compartment... that's it... that piece is pretty flexible, so most likely you will just pull the right side off, and the left side will stay attached... even if it comes off, it's long enough where you don't have to worry, as long as you don't go he-man ape **** on it and yank it into the back seat
Old Nov 16, 2006 | 03:01 PM
xspyder85x's Avatar
off topic: hey D4us0t, is that your refinished trim? get some good pics of it.
Old Nov 16, 2006 | 03:19 PM
D4u2s0t's Avatar
yea it is!! it came out a lot nicer than i thought... even my girlfriend like it, and she doesn't like ANYTHING i do to it! haha... i'll get some good pics... i'm in the process of moving, so i'm not sure where my camera is... once it's done i'll get some up though...
Old Nov 16, 2006 | 03:58 PM
xspyder85x's Avatar
nice, cant wait
back to topic, but i think this topic is over.
Meadowvalien
Aug 17, 2017 06:32 PM
chefhhr
Oct 26, 2015 10:36 PM
Extreme Dimensions
Sep 24, 2015 05:24 PM
dieGone
Sep 23, 2015 10:20 AM
chris88z24
Sep 8, 2015 01:55 PM
