Disable Auto Lights
Old Mar 4, 2010 | 04:12 PM
joey3002's Avatar
Disable Auto Lights
Is there a way to disable the auto on/off function of the headlights on a 2007 ss?
thanks
Old Mar 4, 2010 | 04:14 PM
thedude411's Avatar
turn vehicle to on position not running. hold the bottom 2 buttons for a lil while. scroll through and ull see it as an option. then hit off
Old Mar 4, 2010 | 04:16 PM
joey3002's Avatar
hate to be dumb.. which 2 buttons?
thanks
Old Mar 4, 2010 | 04:19 PM
thedude411's Avatar
the one that looks like a piece of paper with a list on it. and the arrow. left side near the cruise control
Old Mar 4, 2010 | 04:42 PM
joey3002's Avatar
thanks.. I will do that tonight. I have blown several HIDs and only thing I can think of is the constant on/off pulling in/out of garage..
Old Mar 5, 2010 | 07:55 AM
NCC-2000's Avatar
Pull your DRL fuse. It'll blow HIDs more often than turning them on and off with the auto lights.
Old Mar 5, 2010 | 08:14 AM
joey3002's Avatar
Are you talking about Daytime Running Lights? what does the DRL fuse control?
thanks
Old Mar 5, 2010 | 08:56 AM
NCC-2000's Avatar
DRL...Daytime Running Lights...they run at a lower voltage than full power and will screw with HID ballasts.
Old Mar 10, 2010 | 01:20 PM
joey3002's Avatar
odd.. my DRL fuse was blown..
As for the auto on/off feature, i did not see it in the menu.
Old Mar 10, 2010 | 01:27 PM
stoon_cobalt_colby's Avatar
yeah ballasts were screwed due to my drl im just gonna pull the fuse during the day
i just orded a new kit from vvme so we will see if these last
Last edited by stoon_cobalt_colby; Mar 10, 2010 at 01:27 PM. Reason: Automerged Doublepost
Old Mar 10, 2010 | 01:28 PM
joey3002's Avatar
I do not understand what the DRL fuse did? Like I said, mine had been blown for weeks apparently and I didnt notice anything.
Old Mar 10, 2010 | 02:25 PM
lol oh **** maybe my hid kit was fine maybe i just blew my drl fuse i should cheack that out :P
Old Mar 10, 2010 | 02:31 PM
joey3002's Avatar
nono, what I am saying is my 1 HID worked, the other i do think blew... but i put the stock lights back in and never checked the fuses.. Everything in my car worked however, when I just (last night) installed the new HID's, I went to pull the DRL fuse and realized it was blown.
But everything worked fine... so I am asking what the fuse actually did?
Old Mar 10, 2010 | 02:33 PM
hahaha oh icic hmm weird :P
Old Jan 15, 2012 | 07:40 PM
cobalt_sport08's Avatar
Interested in the auto on/off function also... I've ordered a set of 6K HIDs and I know when I install them the DRL fuse MUST be taking out, BUT I've already tried this when I take the fuse out my auto lights still come on during the day. And I don't want my HIDs running during the day for no reason or keep turning them off when ever I turn my car on.. It's hot in FL I don't need any extra heat in or on my headlight lens's lol
Old Jan 15, 2012 | 08:49 PM
Olivier12444's Avatar
DRL makes your low beams to come on during the day. If you install a relay harness (which is recommended with hids) you do NOT need to remove the DRL fuse. As for the auto on/off function there's a thread on how to install a resistor so the sensor always think its day... You then need to turn on your headlights manually!
Old Jan 15, 2012 | 09:00 PM
RooTBeeR's Avatar
07+ this is an issue
drl's run at a lower power than the headlights even though its the same bulb
Old Jan 15, 2012 | 09:03 PM
RooTBeeR's Avatar
guess i should have read up on all the posts before posting, you covered it
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
