DNX 7200 goes into protect mode
Old Jun 7, 2012 | 03:09 PM
Dragonsfire12345's Avatar
Hi, I have a Kenwood DNX 7200 head unit. For the last couple of months its been in protect mode. I looked at the manual and it says that the reason it does this is due to exposed wire. Now I pulled the unit out and checked the back for any problems. I found a couple of uncovered wires and covered them up. This did not solve the problem, so I installed the stock h/u and it still doesn't work and I can hear disturbance in the speakers. I also noticed if I mess with the obdII connection that I hear disturbance in the speakers as well. All my speakers are stock, and the headunit is the only aftermarket part in my audio. Anybody have this problem? Maybe its a common problem, a wire in a certain area gets pinched. Oh I also have the pioneer 10in sub as well.
Old Jun 7, 2012 | 03:51 PM
09turbobalt's Avatar
it might be the factory amp. i know on the kenwoods a blown speaker will cause it to go in protect, but with the factory all of them should play but the bad one but im not 100% sure on that. do you have an ohm meter?
Old Jun 7, 2012 | 03:57 PM
Ok well I think the radio is picking up interference from the obd2. I moved some of the wiring next to the obd2 connector and it works now. I don't have an ohm meter.
Old Jun 8, 2012 | 02:01 PM
EmperorJJ1's Avatar
if u have an ss the wires go right by the ob2 to the amp so id follow them and find where they are touching
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
speedlimit
Site Development and Help
Sep 25, 2015 08:04 AM
Dustonian131
Sep 23, 2015 08:03 PM
bucks121
Sep 12, 2015 07:39 PM
