Driver side HID does not go on high mode
Old Oct 17, 2011 | 04:32 PM
Olivier12444's Avatar
Hello! I just bought an Bi-Xenon HID kit and the driver side bulb won't go on high when I turn them on... Passenger side is fine! I double even triple checked all connections and everything is connected like passenger side! Has anyone ever had this problem?
Old Oct 17, 2011 | 04:36 PM
u need better relays and ground. i'm dealing with the same issue
Old Oct 17, 2011 | 04:41 PM
padlock's Avatar
all i can say is check grounds and then test wiring with voltmeter if need be to be sure the relay is working properly
Old Oct 17, 2011 | 05:44 PM
brickloaf's Avatar
In having the same issue with my passanger side low beam in projectors
Old Oct 17, 2011 | 10:17 PM
If it was not grounded properly, it would not function in low beam mode neither... That's why it is strange! Also, I grounded both sides at the same place (same place on each side), so why one would work and not the other? They are wired exactly the same way.
Old Oct 17, 2011 | 10:36 PM
TommyP's Avatar
AWD > FWD
I'm assuming this is a bixenon 9007 bulb. I would check your fuses first, both the left and right high beam are on seperate fuses. If the bulb is staying in low beam mode and not shutting off completely though, you may have a defective bulb.
Old Oct 18, 2011 | 05:39 PM
It does not turn off on high beam... just stays on low beam... :S
Old Oct 18, 2011 | 05:45 PM
TommyP's Avatar
AWD > FWD
I'm willing to bet either the little motor in the bulb is stuck, or the mechanism is defective. Those 9007 bixenon bulbs have a small motor in them that moves the bulb into the high beam
Position
Old Oct 19, 2011 | 04:57 PM
It is not a motor, it is a magnet XD Which is activated by electricity soooo... maybe there is no power that goes to the magnet... :S I'll try to find out this week-end!
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
no_ss
Oct 18, 2015 11:58 PM
Tupp
Sep 30, 2015 08:18 PM
