DRL Wire
Old Jul 16, 2011 | 12:16 PM
Blue_Balt's Avatar
DRL Wire
I just installed some Gen 1 I bought off a user off here and I'm looking for the drl wire on the headlight harness so I can pull it so I could get the halos as the drl rather projectors.
Thanks.
Old Jul 16, 2011 | 12:17 PM
TommyP's Avatar
AWD > FWD
There is no DRL wire. The BCM controls your DRLs, and sends half power over the low beam wire
Old Jul 16, 2011 | 01:29 PM
NCC-2000's Avatar
Best bet is to pull the DRL fuse then wire up the halos and LEDs to a relay that's fed by a wire that's always on when ignition is on. Even easier would be to just wire them into your parking lights.
Old Jul 16, 2011 | 02:02 PM
Blue_Balt's Avatar
How would I wire them to my parking lights?
Old Jul 16, 2011 | 02:04 PM
TommyP's Avatar
AWD > FWD
Just tap them into the brown wire. It's the Parking light wire.
If you want them to always come on, find a fuse in the fuse box that is only powered when the car is on, then use a fuse tap and draw power from that. Or you could wire them to a wire that always has power, and run a switch in your car so you can turn them on manually whenever you want.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
c_m_shooter
Sep 27, 2015 04:40 PM
jmelton327
Sep 26, 2015 10:04 PM
