Dual Amp and Battery Setup
Old Jan 9, 2013 | 10:45 AM
BlueBaltin's Avatar
I have a MTX Thunder Elite 1501-D Mono block amp and a Kicker ZX350.4 four channel amp. The MTX powers my MTX Sledgehammer and the Kicker of course will be powering my door speakers. I need to know what amperage battery isolator i should use.
I have ordered a pair of Polk Audio db651 6.5" speakers for the doors. Theyre 60w RMS each.
Also have a paid of Polk db691 6x9 speakers for the rear deck. Theyre 100w RMS each.
Kicker ZX350.4 four channel amp should be here tomorrow.
Then finally i have a Kinetik KHC2000 power cell/battery that should be here today.
Should i keep my stock battery as a starting battery in my car until i can get another KHC2000 or just get rid of the stock battery and run the Kinetik?
If i do use both batteries what amperage battery isolator should i get? I was looking at a 200amp isolator but i think that would be way overkill. But its only 25 bucks.
Ive never run two amps before so if anyone can provide me a diagram of how it should all my hooked up id love you forever!
I think thats all i need right now? Thanks for any help!
OH!! and i will be upgrading my Alternator to (probably) 320a...but that wont be for a few more months.
Old Jan 9, 2013 | 10:55 AM
C_A_D88's Avatar
If your running 2 battery's u should have 2 of the exact same battery's new within 6 months of each other minimum
Old Jan 9, 2013 | 11:05 AM
BlueBaltin's Avatar
The Kinetik website says I should run a KHC1400 for starting battery and KHC2000 secondary. it even tells me I can keeps my stock battery.
Posted from Cobaltss.net App for Android
Old Jan 9, 2013 | 11:07 AM
BlueBaltin's Avatar
So you would take out the stock battery and just run the Kinetik? I'll have a second Kinetik in a month. two months tops.
Old Jan 9, 2013 | 11:26 AM
bluebolt713's Avatar
Yes for right now change the stock battery for the kinetik does are strong batterys.ur stock alt will be working harder when you put 2 kinetiks..how many rms watts will you be running
Old Jan 9, 2013 | 11:31 AM
BlueBaltin's Avatar
2000RMS total
Old Jan 9, 2013 | 11:43 AM
Ok i see try to get the alt 1st before getting the 2nd kinetik but a 320amp alt is pretty big u will be fine wit 200amp alt and also try to do the
big 3
Old Jan 9, 2013 | 01:01 PM
BlueBaltin's Avatar
My biggest concern right now is what amperage isolator I should get. I want to go ahead and get one ordered so its here when I'm ready to hook everything up and I'm not having to wait.
Old Jan 9, 2013 | 02:15 PM
If u gonna get the 320 alt u should look for a bigger isolator
Old Jan 9, 2013 | 04:36 PM
BlueBaltin's Avatar
what size isolator should I get?
big 3
what's the big three?
Old Jan 9, 2013 | 04:52 PM
This one is good for a 320alt... http://www.sonicelectronix.com/item_...Bay-IB500.html
The big 3 is something awsome for a bass head jk.....
Old Jan 9, 2013 | 07:46 PM
ROB517's Avatar
The Install Bay IB500 500 Amp Battery Isolator and Relay (ib-500)
Whats this for?
Old Jan 10, 2013 | 03:14 AM
EmperorJJ1's Avatar
why do you want a battery isolator anyway?
Old Jan 10, 2013 | 04:57 PM
BlueBaltin's Avatar
I'm gonna be running 2 Kinetik HC2000 batteries. I don't want them to drain each other.
Old Jan 10, 2013 | 09:27 PM
EmperorJJ1's Avatar
like someone said earlier you should be buying these around the same time for best performance. if that's the case then they will act like a single battery when placed in parallel. What a battery isolator is good for is separating the 2 batteries when the car is off. When running it is supposed to have 0 effect on the 2 batteries. So if you plan on playing the system with the car off often then a batt isolator is a good option. If not then running them in paralell no isolator and minimizing the time the system is playing with the car off is the best option.
Old Jan 13, 2013 | 01:01 PM
BlueBaltin's Avatar
Got everything all hooked up in the balt yesterday. Just waiting on a distribution block now so i can run both amps. Gonna do the big three today or tomorrow. Gotta see if i got enough 0 gauge laying around the run from alternator to battery. Any of you know about how many feet of wire ill need?
Old Jan 13, 2013 | 01:12 PM
redcobalt07's Avatar
That one kinetik battery should be enough for two amps.
Old Jan 13, 2013 | 01:25 PM
BlueBaltin's Avatar
It is. I'll just be replacing my starting battery with a Kinetik also. I'm overkilling the hell out of it I know. But I'd rather overrate than under rate. And I may upgrade in the future again.
Old Jan 14, 2013 | 01:54 AM
EmperorJJ1's Avatar
17-20 is what you will need if you use the gromit by the gas pedal and follow the stock wiring
Old Jan 14, 2013 | 02:03 PM
BlueBaltin's Avatar
Is it run to the battery on the driver side?
Old Jan 14, 2013 | 03:15 PM
EmperorJJ1's Avatar
yes midway thru the car thou it runs thru the middle then to the passenger side at the wheel well
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
cw383
Sep 30, 2015 12:41 AM
Sep 27, 2015 08:53 PM
c_m_shooter
Sep 27, 2015 04:40 PM
