DVD player question
DVD player question
Where and how do I plug the Paking brake wire from a Jensen DVD PLayer???
I don't know alot about this, but im sure I could do it myself, if anyone could tell me where i plug that wire in, i would appreciate it...
The Video works only with the E-brakes engaged but where do i plug that wire?????
you can run the ground wire to one of the bolts under the driver's side panel, just like the fuse box panel on the passenger side but you might want to get a switch and ground it. also what jensen model do you have? if you need the code to bypass the unlawful message let me know.
I have the Jensen VM9311TS
another question, how can i run the music video from the iPod to the screen, Im not sure. I only get a blue screen and sound, if any one knows I would appreciate.
but yeah, i only need somewhere to plug that ebrake cable, ANY BODY please...
There is a way to bypass this on most Jensen units, try this: http://forum.ecoustics.com/bbs/messages/4/278797.html (look at the second post). I have never done it so I cant say if it works or not. Good luck.
head down to your local car audio dealer and tell them that you need a universal trigger output module...i had mine installed and read the instructions and they still baffle me a little bit the model I have is a "Peripheral" PTR-7 I had it installed on my alpine and it works like a jewel without having to go through the bullshit of setting the park brake....hope this helps...btw they are not just + and - inputs i tried it and it doesnt seem to work.....the output module is like $20.00.....IMHO well worth it
**** i finally got it, i open that cover right where the e-brake is and i found the freakin wire that they used to connect to the e-brake, i when to autozone and bought a switch and i just grounded the wire but i needed a switch because you need to do that stupid sequence with the e-brake, "pull up for 3 sec, and pull it down, and up and down." with the switch i just flip it on and off for that 3 sec... works great and very easy to do... thanx all of you that tried helping me out... if any one have a question how i did it in details just ask me later...
Iceberg
Sep 29, 2015 12:33 PM
