Easy-Access Auxilary Power
Original Hayden Fanatic
sunroof is ignition controlled so whatever you spice will shut off w/ the car
cig lighter is constant power...
also there is a fuse box in the passenger side wall you might be able to tap something in there
The boost gauge power is a good idea though.
sunroof fuse I used for my 3sixty and my Amp turn on off....only problem is that the radio still plays till the drivers door is opened, meanwhile the system shuts off when the passenger door opens...(incase you didn't know the Sunroof windows and everything that still run after you shut the car off except the radio shut off when any door is opened, the radio only dies when the times up or the drivers door is opened)
