View Poll Results: EmperorJJ1 what next
Multiple Choice Poll. Voters: 38. You may not vote on this poll
EmperorJJ1 what next?
SPL Dynamics D5
or
Celestra DA6K2, same difference.
I take it cuz the D7 is the same board as the DD Z2, then the D5 must be built on the Z1 platform, but the DD's can't handle the 16, or 18 volts like the SPL amps can
or
So after the voting on this i was going to knock them out one by one in the order of most votes to least votes with the center channel probably ending up last because that's going to suck to do. But i got sorta side tracked....
Ive figured out how its possible to seal the subs up (big issue) and be able to remove it if need be but I've also purchased the rear door speakers (hertz hi energy 165L) purchased the center channel speaker (cdt es-03) finally decided what mids amps I'm going to do and bought 3 of the 4 amps i need (ppi a600 X2 and ppi a200, i need one more a600) and bought a T30001bd with the intention of modding it for 18v use.
But ive found a T40001bd that's factory modified for 18v and i would rather have a bigger amp plus the factory mod over trying to **** with it myself.
So anyone interested in a SAZ 3000D or T30001bd?
I can tell you from experience that when the subs are sealed firing forward that you wont get much upper bass, mine would fall off pretty hard at around 55hz. I did one exodus audio tempest 15 mounted ib, also did an re se 15 same way, done a diamond d9 12 sealed and also done 2 re se 12. All of these were sealed to the front of the rear seatback and all had issues with freq's over 55 hz, have now redone the box and have them firing rearward with the box near the seat and they rock pretty hard all the way up to whatever freq I want to cross them at. The ib sub did sound awesome even though it was limited on where it should have really done its thing.
done the re se 12's in a box also. and the tempest had real close to optimal volume also. dont get me wrong the deep stuff was all there but at around 55 hz it was dead and would come back around 125, had to be a comb.
