Inquiry: Wiring the ACC ignition Cable
Old May 16, 2009 | 04:35 PM
BlueHaze's Avatar
Car: 06 Cobalt
I purchased a wiring harness (metra 70-2103) that did not have an ACC wire in the actual harness. The ACC/Ignition wire came as separate wire that needs to be 'spliced' to either the windshield wiper or sunroof fuses.
Looking at the fuse box can anyone tell me:
1. Where the wires are located
2. What colors are both wires
THANKS
Old May 16, 2009 | 09:51 PM
Acey's Avatar
If you wanna know where the s'roof/wiper fuses are specifically there is a diagram on the back of the BCM/fuse cover, look in there or in the manual. As for acc/ig wires, I'm not sure.
Old May 17, 2009 | 12:22 AM
EmperorJJ1's Avatar
tapping the actual wires themselves is going to be pretty much impossible your going to end up tapping the fuse in some way shape or form
Old May 17, 2009 | 10:37 PM
BlueHaze's Avatar
Yup I figured it out by putting the ignition wire in the wiper fuse! The head unit works great!! I went with the Pioneer AVH-P4100
Old Jun 1, 2009 | 06:32 PM
Hodz's Avatar
Is there a harness that has the ACC/Ignition wire in the harness?
Old Jun 1, 2009 | 06:58 PM
EmperorJJ1's Avatar
yes... if you have an 05-06 u can get the expensive harness thru pac and have double the turn signal/chimes or if you have an 07 the metra gmlan has the acc
Old Jun 1, 2009 | 08:56 PM
Hodz's Avatar
Yea 120 doll hairs doesnt sound worth it lol... For metra one does it matter if you have onstar or not? I have an 06 with onstar. I dont use the onstar so I could care less if it works or not. Also how do you tap the fuse? What do you need? I looked for a how to but the only one I found the pics werent working.
Old Jun 1, 2009 | 09:27 PM
EmperorJJ1's Avatar
then buy the cheap harness(70-2103) and run an acc wire like every other 06 out there. trying to make onstar work for us is stupid difficult so luckily you don't care for it
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
footballplaya3k
Sep 30, 2015 09:39 PM
jmelton327
Sep 26, 2015 10:04 PM
