Equalizer curves on stock Head Unit with Pioneer
Old May 28, 2014 | 07:49 PM
mrfitz's Avatar
This may sound weird… But does anyone know where I can find the EQ curves for the stock head unit? For example, if I boost the bass one notch, I want to know how many decibels it boosts at which frequency (most likely a shelf eq).
The reason I need to know this is that I am an audio engineer, and I check the songs I work on in the car, and make adjustments if necessary.
Thanks in Advance.
Old May 28, 2014 | 10:40 PM
Crav3's Avatar
You cant. But it will show you the curve when you adjust the bass and treble accordingly
Old May 28, 2014 | 11:26 PM
mrfitz's Avatar
Well, yeah, that's obvious that it shows a generic display.
What I'm looking for is actual specs on the equalizer in the radio. Even just the crossover frequencies in the EQ would be great.
Old May 28, 2014 | 11:36 PM
Dyn0mitemat's Avatar
Put a tone generator on the aux in and get a db meter if its that important
Old May 29, 2014 | 12:03 AM
mrfitz's Avatar
You mean, run pink noise (which contains all frequencies) through the aux, and run frequency analyzer software to measure the changes in gain in each band.
Yes, I understand, but what I'm looking for is factory specs and exact crossover points.
Thanks.
Old May 29, 2014 | 03:11 AM
EmperorJJ1's Avatar
gl bro thats gonna be hard if not impossible to find. what if you just leave it "flat" which im sure you know its not a true flat
what kind of music do you make?
Old May 29, 2014 | 05:18 AM
mrfitz's Avatar
Well, the "car reference" is a final check to listen on consumer speakers. I also listen on a bose iPod dock radio, same concept.
I listen in the car with the same settings that I listen to all music, so the perspective is the same.
(bass 3, mids 0, treble 3)
Sometimes, if I feel the bass is too light on the song, I will turn the car stereo bass up a notch for a second to see if that fixes the problem. Then I immediate put it back to 3. Then I go inside and adjust the EQ on the song.
I work mainly in the Rap genre here in Atlanta, but also work with Rock.
Old May 29, 2014 | 08:18 AM
Best of luck, gotta say the stock head unit is really bad at emitting mids.
link to music? i'm a rapper. look up Tangent_ on soundcloud if ya want
Old May 29, 2014 | 10:18 AM
EmperorJJ1's Avatar
nice. ive never been a fan of that eq style myself but most tend to go with something along those lines
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Trav3480
Oct 1, 2015 08:17 PM
Stuff
Oct 1, 2015 05:47 PM
