fog light switch ?
Old Mar 24, 2011 | 09:15 AM
FITZ07's Avatar
fog light switch ?
OK, I have a 07 LS without the factory wiring built in for the fog light swith on the dash. Was wondering if anyone knew what wires I would need to run where to make it work if I got the plug from the junk yard. Will be installing a new gm light harness with fogs to the fuse box under the hood.
Old Mar 24, 2011 | 09:51 AM
Nighthawk243's Avatar
Factory fogs are run through the BCM. It is much easier/cheaper to wire in a standard rocker switch instead and use relays to enforce the "turn off with high beams" rule.
Old Mar 24, 2011 | 09:09 PM
FITZ07's Avatar
Ya, I know it would be cheaper to go aftermarket, but I like a challenge. And I'm kind ****. Anyone??
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
