free battery?
Old Apr 16, 2009 | 11:02 PM
brickloaf's Avatar
free battery?
my friend had a extra battery that he used for like 6 months in his jetta, he let me have it for some reason, my question is should i even use it (for my amp) its a Duralast that outputs 760 amps and 590 cold cranking...
sooo should i keep it or trash it
Old Apr 16, 2009 | 11:45 PM
stinkyfisherman's Avatar
If you do use it remember that it has to be hooked up. This will put more of a strain on the alternator cuz it will have to charge two batteries instead of just one.
Old Apr 17, 2009 | 08:23 AM
brickloaf's Avatar
yea i know ill need a isolator, but should i even use it for my amp? or is it at least better than the stock battery (if so ill just switch it out with the regular battery if the amp dosent work out)
Old Apr 18, 2009 | 12:09 AM
HunterKiller89's Avatar
im almost positive its better than stock, but not 100%. I think the stock battery pushes either 500 or 550 cca's
06MetallicBalt
Jul 20, 2025 08:47 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
