Fuse blowing - stock amplifier
Old 03-24-2007, 09:29 AM
Kidder's Avatar
Just bought a 2007 Silver Cobalt SS (non-supercharged) yesterday. The stereo turns on but no sounds comes out. Unfortunately, the dealer said to bring it back Monday so they can fix it. So, I'm bored reading through the manual and see that the amp has its own fuse (of course). So, I go check it and it's blown (20A). I go get a replacement fuse and put it in. I immediately get feedback coming from the rear sub and the fuse blows. Any ideas?
Old 03-24-2007, 09:31 AM
D4u2s0t's Avatar
put the stock one back in. if you changed it, and it's blown, there probably going to blame it on that. other than that, let them take care of it. it's a brand new car, not your responsibiltiy to try to fix it.
Old 03-24-2007, 11:08 AM
Kidder's Avatar
First off, they already know that no sound is coming from the stereo. So, they know they're on the hook to fix it. I was just hoping it was something easy or obvious that I could fix.
Old 03-24-2007, 11:15 AM
D4u2s0t's Avatar
yea, i'm not too sure about the electronic side of things. i wouldn't even know where to begin to tell you to look. some of the guys here are much more experienced with that kind of thing, it's still early though, i'm sure they'll be on later.
clint06ss2.4L's Avatar
To me it sounds like a bad factory ground. It has happened to me in the past with amps. Either factory or aftermarket. The ground makes a huge difference.
Old 03-24-2007, 06:12 PM
Kidder's Avatar
I'm in the same boat as you, I'm pretty ignorant when it comes to this sort of stuff. Oh well, I'll let the dealer figure it out.
Old 03-24-2007, 06:18 PM
Sunburst_SS's Avatar
sounds like a short to ground....if that's the case, going to have to test the circuit and find the damaged wire/connection
Old 03-24-2007, 09:32 PM
Xavipheus's Avatar
Dont mess with it, it might be a bad ground, or a faulty power supply in the amp, or any other of a million things. Leave it alone, not worth messing with when you can have them fix it tomorrow.
Old 03-24-2007, 09:34 PM
I doubt it would be a bad ground. I think if the fuse keeps blowing it's a power supply wire that is grounding out causing the fuse to blow.
Old 03-25-2007, 05:49 AM
EmperorJJ1's Avatar
ditto on that
Old 03-31-2007, 10:00 AM
Kidder's Avatar
Fixed
Took the car in and got it back within hours. They did a test and the amplifier was bad. So, everything works great and my wife loves her new SS.
Thanks for everyone's suggestions!
Supercharged06SS
12-11-2022 04:47 PM
Zharrington_2010LNF
02-08-2016 01:43 PM
10-13-2015 09:32 PM
Stuff
10-01-2015 05:47 PM
MrInsanityWolf
09-29-2015 04:54 PM
Quick Reply: Fuse blowing - stock amplifier
