Fuse Box Help
Old Jun 25, 2008 | 10:41 PM
Dieter's Avatar
Fuse Box Help
OK first of all ebfore I even start, I have little knowledge on this subject obviously, I had my system installed and told it would be "professional" yeah right... I know enough about electronics to notice that this is bullshit....
Sorry about how blurry they are, only got my cell phone camera
So I talked to another member to this forum and was told to get a fuse tap, so I got one, but it won't fit in the current location. Then I remembered, when i first had the system installed, it was hooked up to the "trunk outlet" so I used the fuse tap and connected my system to the "trunk outlet". Well my system still works but.... I lost the trunk release button functionality. Somone please help me... where should I hook my system up to... I've brought it back to the shop 3 times and each time they did something new to it and it looks more and more unprofessional every time. ( just a little background info at first they told me there was no way to get the wire from the system properly on a fuse, and they wanted em to give them 300$ for a din kit, that costs 30$)
Old Jun 26, 2008 | 02:21 AM
EmperorJJ1's Avatar
damn thats trashy... unfortunatly ive seen it before. The fuse you want to tap is either the sunroof or windshild whiper fuse both located on the inside fuse box (lower passenger left hand side). You can either do the conventional fuse tap with connector or solder the wire on. Just make sure to tap the side of the fuse without power
Old Jul 2, 2008 | 05:09 PM
Dieter's Avatar
OK took me a bit to figure it out, didn't realize I needed to have two fuses on the tap for both things to work ( windshield wipers and my system ). But I got it working now and thanks for everyones help.
Old Jul 3, 2008 | 02:05 AM
EmperorJJ1's Avatar
no problemo
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
c_m_shooter
Sep 27, 2015 04:40 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
