FYI - the HHR head unit doesn not work
Old Dec 18, 2005 | 01:52 PM
SilverSS/SC's Avatar
I wanted the HHR CD player because of the I-pod jack and in-dash 6 disc , its XM and onstar ready thru GM lan , and it looks so much better . The face coulda been painted silver to match . Figuring since the HHR is the same chassis as the cobalt , underneath on GM platform sharing cars the wiring is typically the exact same . I bought one , and it doesnt work . The plugs are totally different , its actually even a bit bigger than the Cobalt DD head unit too and wont fit the bezel , though it does slide right into the slot and side mounting rails are the same . Also the stock SS radio has a bow contour to the face , the HHR radio is flat as a board . "IF" fittement wasnt an issue I would crossed the wires to a HHR connector to see if it woulda worked , but given that I didnt bother .
Overall bummer , I didnt and dont want a aftermarket head unit . The I-pod jack and in dash 6 disc would been nice . The 2006 Ions even got this headunit One thing wierd I found , is that its not a Delphi . Fujitsu makes it , first non-delphi head unit Ive ever seen in a GM .
Old Dec 20, 2005 | 12:48 AM
Clmbngfrk18's Avatar
well even if it did fit it wouldnt work due to gm's protection system your radio is linked to your vin number and reads it from the computer every time it turns on but also most likely the reason it not a delphi is becausethey had to declare bankruptcy
Old Dec 21, 2005 | 01:37 PM
DETROITGT's Avatar
The radios were in place long before Delphi filed bankruptcy, so I don't think that was a reason why they are not Delphi.
BTW guess who owns a substantial share of Fujitsu? GM. So most GM/Delphi radios are probably built/assembled by Fujitsu and labeled Delphi.
chefhhr
Oct 26, 2015 10:36 PM
Hugger1975
Oct 15, 2015 03:28 PM
Extreme Dimensions
Sep 24, 2015 07:51 PM
Turbo6
Sep 24, 2015 04:15 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
