Gm05
Old Jul 8, 2006 | 02:34 AM
halfj99's Avatar
Gm05
is that the correct Scosche wiring harness?
says for 2000+ tracker and montana, but i bealive its ours also...can somone confirm that for me,it kind of urgent
Old Jul 8, 2006 | 09:22 AM
Raven's Avatar
no. it's the same harness as the 2004+ Ion
Metra 70-2102
the only downfall is there is no amp yurn-on on this harness. so if you have pioneer, connect the factory pink wire to your blue/white on the deck. and you'll need to run your own switched source still
Old Jul 8, 2006 | 05:41 PM
halfj99's Avatar
so it would be GM10B from scosche, i would imagin theres has an amp turn on
Old Jul 8, 2006 | 08:26 PM
Raven's Avatar
yes that's it too
Old Jul 12, 2006 | 11:56 PM
slamedham's Avatar
huh... so is it the gm05 or not... :| i just picked u pthe 05
Old Jul 18, 2006 | 06:35 PM
Raven's Avatar
Metra 70-2102
is the right harness. but the cobalt has no switch 12v. so you will need to run a switch wire
slamedham
Jul 11, 2006 03:03 PM
