head unit help/advice
Old Mar 1, 2009 | 01:29 PM
trino36's Avatar
allright for starters i am an electronics illeterate. just that i would let you know that off the bnat so you know what you are dealing with. now i want to get an in dash touch screen radio/dvd/ navi/with ipod hookup. I dont want a flip out. i searched the threads n stufff didnt really find what i was looking for other than pioneer eclipse n alpine are the best but i was already leaning toward pioneer to keep it alll the same. now i had a dakota and i put a sony xplone stero and 6x9s in it n it sounded like ****. so i dont want that to happen i like the way the stock stero sounds i just want all the other frills. so this is my question to you what stero would you reccomend that woud be dvd/ navi/with ipod hookup non flip out n not make the system sound like **** brand and model and xm would be nice tooo thanks!!! sry so lond! !!!
stereo * (for proper spelling)
Old Mar 1, 2009 | 01:42 PM
jerry357's Avatar
do you have the premium pioneer or just base stereo in it because you might need an adapter of sorts to work with the pioneer. just go to crutchfield.com and enter your car and model and they will show you what fits it`s called outfit your car,anyway heres a link to some kenwoods that will fit our cars.
http://www.crutchfield.com/g_168550/...rand%7cKenwood
Old Mar 1, 2009 | 01:47 PM
trino36's Avatar
it has the pioneer systen w/ the sub thanks
Old Mar 1, 2009 | 01:51 PM
jerry357's Avatar
yeah then go to crutchfield.com and it will tell you everything you need to make the wiring connections and they usually have pretty good deals on stuff. hope this helps
Old Mar 1, 2009 | 01:54 PM
trino36's Avatar
thanks!!!!
Old Mar 1, 2009 | 01:59 PM
jerry357's Avatar
welcome
Old Mar 1, 2009 | 02:06 PM
EmperorJJ1's Avatar
what yr car
Old Mar 1, 2009 | 09:02 PM
Nakaiya21's Avatar
I am biased, but I recommend the pioneer F90-BT.... that is what I put in mine. Since you claim to be electronic illiterate I would recommend paying to having it installed...It is not an easy install by any means
Old Mar 2, 2009 | 08:10 PM
trino36's Avatar
what did that run you??? and i will def have some1 install. i have a 2006
Old Mar 2, 2009 | 08:33 PM
EmperorJJ1's Avatar
06 is alot easier then the 07 then. you don't need the expensive harness the regular 10-15 dollar one is fine.
personally i would lean towards kenwood if you want navigation. any of the dnx series have garmin navigation and its alot more user friendly IMO
Old Mar 2, 2009 | 08:47 PM
trino36's Avatar
i really like that kenwood dnx is that going to affect the quality of sound compared to my stock radio??
Old Mar 2, 2009 | 10:40 PM
EmperorJJ1's Avatar
yes. any radio will do that thou. our stock hu has line level output vs the speaker level output on all aftermarket hu's. basically the volume starts off louder and continues to get louder until it distorts with alot more volume left to go. its not the best situation but for a daily driver nothing crazy audio wise you should be fine as long as you don't just totally blast it.
Old Mar 3, 2009 | 05:21 PM
trino36's Avatar
will my steering wheel controls still work if i o aftermarket???
Old Mar 3, 2009 | 05:26 PM
koch1ar's Avatar
u'll have to buy another harness for wheel controls
Old Mar 3, 2009 | 11:57 PM
EmperorJJ1's Avatar
x2 look into the pac audio steering wheel interfaces
Old Mar 5, 2009 | 10:45 AM
jdopp911's Avatar
I just put in an eclipse avn 6610 double din and i hooked it up with the cheaper harness in my 06 cobalt. Before i had taken out the stock sub and put in a pioneer premier 10", one of the best slim subs, made absolutely no difference. but when i put that new double din in..... SOOOOOOOOOo much louder and clearer on sub and every speaker.
Old Mar 5, 2009 | 09:04 PM
trino36's Avatar
what is a double din???
Old Mar 5, 2009 | 09:21 PM
koch1ar's Avatar
Our stock radio is a lil bigger than a double din. 1 Din is the stardard size for aftermaket radios. You'll have to buy a dash kit for whatever you buy single or double
Old Mar 5, 2009 | 09:29 PM
trino36's Avatar
ok i get it thanks
Old Mar 7, 2009 | 04:10 PM
Fishers24's Avatar
one thing you need to rember esp if u have the pioneer up graded system you need to get an antena adapter
another thing u can do insted of buying the harness is just use ur dmm (multimeter) for power and ground.. acc is kinda hard to find cause the car dose not use it it uses data 2 but their is 2 brown wires running out of pin 14 i believe it is on ds bcm or on passanger side their is a thick pink wire u will get acc from ..... then just run new rca cables for ur amp
Old Mar 9, 2009 | 12:25 AM
trino36's Avatar
i have no clue what all that means?? lol im gonna have best buy hook it up will they know all of this??
Old Mar 10, 2009 | 11:28 PM
Fishers24's Avatar
yo it simple man all u need is power ground and acesory to turn it on and wire it to the speaker u just need an antenna addapter ... trust me dont go to best buy
Old Mar 11, 2009 | 02:16 AM
EmperorJJ1's Avatar
what are you talking about fishers?
Old Mar 11, 2009 | 10:01 AM
freakta's Avatar
do they sell the harnesses for the car yet?
Old Mar 11, 2009 | 11:49 AM
EmperorJJ1's Avatar
yup theres a good handful of them. hit up the FAQ sticky for more info. oh if you can rear the whole thread seeing as i cant update it anymore theres some useful info at the end
