Headlight issues
Old Apr 7, 2012 | 01:25 PM
Scipe's Avatar
Headlight issues
Need a little help.
I have a 2006 SS with stock headlights. When I unlock the car the passenger side will come on and not the driver side. When I turn on my lights the driver side will come on and not the passenger. When I turn on my high beams the driver side goes off and passenger will come on.
If I put in new lights they will work fine for about 3 days but start doing the same thing.
I've checked the fuses for high and low for both sides, all good. Is there a relay that I can check? Is this a wire issue?
Any help will be greatly appreciated.
Old Apr 7, 2012 | 01:42 PM
Dart_SI's Avatar
I would try checking the wiring. You could replace the headlight harness pretty easy.
If its not that I suspect a bad ground somewhere, which is always fun
Old Apr 7, 2012 | 02:11 PM
Scipe's Avatar
Yes sounds like a blast. LOL! Thanks for the options to try.
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
