headunit not dimming.
So i just installed an AVH-X5600bhs in my 2010 cobalt LT sedan.. everything works perfectly except the dimmer. Im running the proper metra/axxcess wiring harness and one thing that I did notice is that both the illumination and dimmer wires go nowhere... being on the metra/axxcess side they are there but on the factory harness size there is no wires. I saw that its suppose to be a gray wire but I dont see it anywhere.
Does anyone know what pin and which plug the factory illumination wire goes? I found them for the upgraded radio and other years, just not for my 2010
Head Unit Power
Wire Color Polarity Location Plug/Pin# Note
Battery RED/WHITE (+) RADIO HARNESS C1 PIN 1
Accessory THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE.
Ground BLACK/WHITE (-) RADIO HARNESS C1 PIN 8
Illumination GRAY (+) RADIO HARNESS C1 PIN 2
After lots of research I finally found a thread talking about this. I guess I need to find another source now.
ps... I am the op. I forgot I made this SN years ago when I was in the market for an ss
depending on how tech savy you are theres 2 options if you must have illumination (not dimmer btw)
1 module harness. the box decodes the data signal and gives u illumination
2 think alarm... when you install an alarm you have to tap somewhere to get a headlight signal. I did this on my old 06 and it worked fine but if you dont know what your doing you probably shouldn't try this
