Help installing a remote starter/keyless entry or programing remote
Old Jan 19, 2013 | 06:56 PM
AChap52's Avatar
Like most cobalt owners, my keyless entry remote does not work. So instead of buying a new remote for $40 and having it programmed for $50, i thought i would maybe try to install a nice aftermarket one myself for around $150. I really don't know the first place to start but i can't imagine it being all that hard. I've always wired up all my stereo stuff, so i know the basics. My second option is that amazon has stock cobalt remotes that have the remote start button on them, what would i need to do to get that to work on my cobalt ss that doesn't have remote start?
I heard that our remotes have to be programmed through the obd2 port with some scanner. I have a obd2 to bluetooth adapter. Are there any programs that you guys know of that i can use to program the key for myself?
Thanks for any help
Old Jan 20, 2013 | 03:06 AM
EmperorJJ1's Avatar
is your car auto or standard?
Old Jan 20, 2013 | 04:54 AM
serega12's Avatar
He did say it won't work on his Cobalt SS..
Thanks for any help
Remote is $15 on ebay...
Chevy Buick Pontiac Saturn 4 Button Key Keyless Remote Fob GM 15252034 | eBay
Programming should be complimentary at your local dealer. I know mine did it for free.
Old Jan 20, 2013 | 05:20 AM
EmperorJJ1's Avatar
^^^^ best option. although i dont see the cobalt ss part
Old Jan 20, 2013 | 09:28 AM
Gelladuga69's Avatar
Programming will run you a half hour of labor.. So $50.
Old Jan 20, 2013 | 01:35 PM
M47TYB's Avatar
do you know what you need to program it? thats outrageous...:/
Old Jan 20, 2013 | 02:48 PM
A Tech2 or similar.. My locksmith has a Tech2 and another device, which I don't know the name of but is probably just as expensive, to do FOB programmings.
Old Jan 20, 2013 | 03:17 PM
serega12's Avatar
A lot of times it's not in the title of the listing... You need to take apart your broken remote and verify the part number etc. GM used a lot of the same remotes across different models/trims.
IF your dealer wants to charge you. A lot of times they want you to come back for other services, so they won't charge you for something as little as that (literally took my dealer 5 minutes, he didn't charge me anything when I came in with two remotes a while back for my HHR before I sold it)
It's at service adviser's discretion, and GM dealers in my area are pretty cool about that.
Not necessarily, Gelladuga69... If you look up instructions for programming remotes for GM, there is a way to program additional keys and remotes, but only if you already have a couple of working/programmed ones. Good idea to do once you have a couple of properly working remotes, especially if your dealer DOES charge you.
Old Jan 20, 2013 | 03:24 PM
CTcar's Avatar
My remote stopped working too. Take it apart and check the battery solder. Also put little pieces of tin foil (I used aluminum tape) under the rubber button part. The coating that makes them conductive wears out and the remote stops responding. Works perfect now like brand new
Old Jan 20, 2013 | 03:33 PM
serega12's Avatar
Solder on my battery holder on my spare remote fell off too...
Old Jan 20, 2013 | 06:01 PM
AChap52's Avatar
This is what happened to me, the battery holder broke and it was a long shot at fixing it and i messed it up even worse because my soldering gun is the size of my car....
Old Jan 20, 2013 | 06:12 PM
AChap52's Avatar
My part number is 22733523. Would that remote still work for mine?
Old Jan 20, 2013 | 06:22 PM
Hexonxonx's Avatar
I bought my remote at the dealer and the guy said he would do it for a tip. I gave him $10. I think the remote was $60.
Old Jan 20, 2013 | 11:14 PM
serega12's Avatar
My part number 22733523. Would that remote still work for mine?
Here's an even better deal for you... 3 for $24.
Lot of 3 GM Remotes Keyless Entry Remote FCC ID 22733523 | eBay
Or just look through any of these listings:
gm remote 22733523 | eBay
Old Jan 21, 2013 | 04:30 PM
AChap52's Avatar
Standard...
Old Jan 21, 2013 | 09:40 PM
serega12's Avatar
Standard...
Correct me if I'm wrong, but I thought every SS came with standard....
Old Jan 21, 2013 | 10:56 PM
AChap52's Avatar
2.4 N/A SS came with an optional 4 speed auto...
Old Jan 22, 2013 | 12:47 AM
EmperorJJ1's Avatar
Standard...
then you will want to take it to a shop
Old Jan 22, 2013 | 01:37 PM
AChap52's Avatar
I don't want to take out a loan, I'll just stick with my good ol' key
Old Jan 22, 2013 | 02:39 PM
EmperorJJ1's Avatar
lol yup sorry but since i used to work at a shop and ive seen people not only learn how to do alarms in a professional environment but also customers attempt to do alarms and call us when they failed... your not to install your first manual alarm correctly
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
reybalt
Sep 27, 2015 07:57 PM
