HELP!! New Head Unit Wiring Question!
Old Apr 15, 2011 | 07:22 AM
barrett's Avatar
I recently bought an Alpine IDA x305s. I decided to install myself, I mean how hard could it be, the wires are all color coded.
My issue comes after I have the unit installed. When I turn my signal lights on, the Unit shuts off, and I don't here the sound of the signal light (the ticking noise). When I turn the signal lights off, the unit comes back on.
I'm pretty sure I connected all the wires correctly, but it was beginning to get dark when I was doing it, so I am going to double check them.
Any suggestions as to what the problem might be?
I'm driving a base model 2010 Cobalt by the way, no steering wheel audio controls, not extras... just a Cobalt. And yes, I realize this is simple, but it's my first installation so I'd appreciate some help.
Thanks
Old Apr 15, 2011 | 09:23 AM
barrett's Avatar
Old Apr 15, 2011 | 09:37 AM
punksk8ter62's Avatar
all the wires are color coded to the plug and play harness you hopefully bought. except the power(red) and that goes to the fuze box on the passenger side of the car. i believe i hooked mine into the sunroof fuze. idk if its diff between the SS and the base. but its pretty simple. check all your wires and make sure you didn't cross any.
Old Apr 15, 2011 | 09:54 AM
jmesl8er's Avatar
what kind of wiring harness? Did it come with a speaker? How much was it?
Old Apr 15, 2011 | 10:05 AM
BartSS's Avatar
You should have paid like 100 for the harness for it to work correctly. I didnt wanna spend the miney so i just bypassed it knowing that my onstar wont work and my i will haveno clicking noise with my blinkers.
Does it look like this? 2004-up select 11 bit stereo replacement interface
Old Apr 15, 2011 | 11:50 AM
barrett's Avatar
jmesl8er: The wiring harness came from Crutchfield, don't remember the name/brand or whatever but they sent out with the unit. Everything came specifically for my car with the unit.
VBartSS: it did not look exactly like that, but I didn't by pass anything, everything is connected.
punksk8ter62: I will be double checking the wires, because it was starting to get dark as I was connecting them, but with regards to the red wire, there was one coming from the PAC adapter (required for chimes, etc to work on GM vehicles) and one coming from the harness that plugs into the head unit. My understanding was that these two red wires should be connecting together. Is this incorrect?
Old Apr 15, 2011 | 12:16 PM
jmesl8er's Avatar
sounds like you got the wrong thing. Mine was almost a 100 bucks, and it does all the chimes in the car too
Old Apr 15, 2011 | 12:18 PM
jmesl8er's Avatar
thats the one i have^^^^^^^^^
Old Apr 15, 2011 | 12:26 PM
barrett's Avatar
it's the PAC adapter that I have, C2R GM11.... it's more then 100 bucks, and this is the correct adapter, that much I know
Old Apr 15, 2011 | 12:39 PM
jmesl8er's Avatar
Old Apr 15, 2011 | 12:47 PM
I used the adapter that crutchfield sent me. I had to run the power to the fuse box tho. I can post pics when I get home if u need to.
Old Apr 15, 2011 | 03:00 PM
barrett's Avatar
I also used this adapter from Cruthfield.... but I didnt attach to the fuse box... Surem if you can post pics, it'd b great
Old Apr 15, 2011 | 03:54 PM
Old Apr 15, 2011 | 03:55 PM
and that wire runs all the way to the red power. But i was reading everybodys posts and could possibly be cause my car is an 05' =)
Old Apr 15, 2011 | 06:12 PM
jmesl8er's Avatar
Yeah, I did'nt have to splice into anything with my kit
Old Apr 16, 2011 | 04:19 AM
EmperorJJ1's Avatar
the module harness is busted contact pac or whoever for a warranty
Old Apr 16, 2011 | 08:05 PM
barrett's Avatar
Just a simple update for you guys, I pulled the unit, and on the PAC adapter there is a button to turn the chimes off/on... when the chimes are turned off, there is no issue at all... I call tech support at Crutchfield and they told me basically what I wa suspecting was the issue.. I need to get a SPDT Relay because there is not enough power going to support the deck and the signal light chimes.
I'll update when I install the relay to make sure it worked.
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
agentirons
Oct 16, 2015 02:11 AM
Trav3480
Oct 1, 2015 08:17 PM
Sep 28, 2015 12:51 PM
