help please!!!
help please!!!
alright so listen, I painted my interior trim. didn't break any clips, harnesses, wiring anything...but now my gauges won't go on. or any other my interior lights for that matter, with the exception of my mirror lights. any ideas? I'm pretty pissed. kind of difficult to drive at night without a speedo or tach
thanks!
thanks!
nah man...the harness for the dimmer switch (makes it lighter and brighter) all of the connections are fine from what I can see. the only thing that got messed up was the small backlight for the foglight switch got ripped off but I soldered it back in...and that shoudn't effect it anyway. all of the wires look like they're connected to the pins in the harness. maybe I'll see something in dayight but even with a bright ass flashlight everything looks tight as can be
x3
You have to disconnect the neg lead on the battery when you pull any wire harness apart. Otherwise when you re connect them you blow a fuse, which I guess you found out the hard way (I think we all did for one thing or another)
lol it appears as though I learned the hard way....I'm gonna go check my box now...I'm assuming I'm looking for fuse #7 (as per the manual its the "cluster") here's hoping that's all it is
ok I'm at a total loss. no blown fuses. no VISIBLE loose connections. hooked up the dimmer switch harness to a voltmeter and it was dead, no power. the foglight switch is totally functional and has power.
cliffs:
no blown fuses
basically all of my backlighting is not working
my DIC is working
HVAC controls working as well as the indicator light to show when ac or defroster is on etc
HVAC back lighting not working
Can't find the loose connection anywhere...anyone have any ideas?
bump to the topppppppp
bump?
cliffs:
no blown fuses
my DIC is working
bump?
Last edited by boostaddict; Aug 10, 2008 at 01:45 PM. Reason: Automerged Doublepost
Check the fuses and the relays under the hood, sounds like it localized itself to one system so it should be easier to track back through the car.
follow the wiring to the source , taking readins along the way, when you find power you know you have gone to far
anyone have any particular fuses in mind? I checked the ones that I think it is but throw some out there...
ok so here's where my mechanics and I have gotten. there's a fuse under the hood fuse box for daytime running lamps. something is overloading the circuit because everytime we put a fresh fuse in there it pops it immediately. so, there is a wire, somewhere, that is grounding out and causing a short and for my car to eat fuses. so we have to try and track it down. ******* crazy.
what I don't understand is that all I did is literally take the plastic off and unclip everything. I changed a strut on a mercedes today, and I've never changed a strut before, without any problems. but I touch plastic and **** gets fucked up. what the ****...
I have a feeling that your problem was already there, you just agrivated it when you pulled your trim out. You might want to check the molex at the door, maybe pulled a wire loose when disconnecting the plugs.
If you do what emp says and it solves the problem, re hook them up in small groups, it will take a while but at least you'll narrow down the area the problems coming from. Also check that backlight you fixed for resistance, a small speck of soder in the wrong place might not be all that visable but could cause problems.
If your poping fuses right away then your shorting somewhere, maybe the wire was already knicked or cut and when you puulled things apart changed its position to touch something metal
I feel for you guy, this must be frustrating....hang in there. These things are usually easily fixed and starring you right in the face, there just overlooked.
