Help With Sub
Old Sep 30, 2012 | 02:50 PM
iToastie's Avatar
Help With Sub
So I purchased a stock Pioneer sub and enclosure for our cars from someone.
I want to eventually wire it up.
I know I'll need an amp, but what kind of amp, how much wattage, etc. would I need for the stock 10" shallow pioneer sub?
I am eventually going to upgrade the stock head unit to a 7" touchscreen, but that probably wont be for a while.
If I got say a 500 or 600 watt Amp now to power my Sub, could I keep it and use it to power everything else once I upgrade my head unit?
Thanks for any help
Old Sep 30, 2012 | 02:58 PM
xxenjoi11's Avatar
a mono block amp is what you want.
match up RMS watts from the sub your using, im not sure on stock sub wattage
Old Oct 1, 2012 | 05:04 AM
EmperorJJ1's Avatar
for the stock sub its a D2 so id get a 2 channel. and no you cant use the same amp to power speakers and the sub unless it has the channels to do so (such as 5 or 6 channel or possibly 4 or 3)
Old Oct 1, 2012 | 02:06 PM
iToastie's Avatar
So what wattage AMP should I be looking at?
Old Oct 1, 2012 | 02:50 PM
EmperorJJ1's Avatar
200w RMS the most
Old Oct 1, 2012 | 02:52 PM
reduf99's Avatar
sjc0013 Licks windows
You get no help! Hahahaha i dont have the smarts for this
Old Oct 1, 2012 | 02:54 PM
ROB517's Avatar
what do you mean everything else?
Old Oct 1, 2012 | 08:17 PM
iToastie's Avatar
Power my speakers/head unit/sub
Old Oct 2, 2012 | 02:00 AM
EmperorJJ1's Avatar
ya no you need separate channels at the very least
Old Oct 10, 2012 | 04:32 PM
iToastie's Avatar
How's this one, just to power the stock sub?
I honestly don't even know what to look for in an Amp.
Rockford Fosgate Prime R250-1 Mono subwoofer amplifier — 250 watts RMS x 1 at 2 ohms at Crutchfield.com
Old Oct 11, 2012 | 12:51 AM
EmperorJJ1's Avatar
while a good amp what you are going to want is a 2 channel amp. You will have to run the stock amp in series for a 4 ohm final load.
Old Oct 11, 2012 | 12:59 AM
Validater's Avatar
For the record I blew up a stock sub trying to do what you are. I powered it with a Rockford Fosgate amp rated for 175 RMS, Dual channel, Each sub coil had its own amp output. Blew it up within a month.
Old Oct 11, 2012 | 01:02 AM
EmperorJJ1's Avatar
you should never run a sub on different channels per coil
Old Oct 11, 2012 | 01:05 AM
Validater's Avatar
Yeah, I had done that just for the lolz, I already had a new 10" sub and new amp lined up so just threw together what I had for fun.
Old Oct 11, 2012 | 02:07 AM
iToastie's Avatar
Think you could help point me in the right direction of an amp?
Old Oct 11, 2012 | 02:42 AM
EmperorJJ1's Avatar
Arc Audio KS 125.2BX2 Mini
Rockford Fosgate Punch P200-2 2-channel car amplifier 50 watts RMS x 2 at Crutchfield.com
Rockford Fosgate Punch 225.2 Car Amplifier | eBay
Old Oct 11, 2012 | 03:01 PM
iToastie's Avatar
$200 is pretty high for my price range. I was thinking around $100
But now I at least know what you mean. at max 250 watt at 2 ohms, with 2 channels
Old Oct 11, 2012 | 10:53 PM
EmperorJJ1's Avatar
thats why i posted the last one. first two are pretty pricy. but 250w at 4 ohms with 2 channels
