hid no low beam
Old Mar 20, 2015 | 09:28 AM
jcod47's Avatar
hid no low beam
Hi everyone i am having an issue with the hids in my ss. Its an 05 and they are ddmtuning 55w bixenon in factory headlights. Ive had them for over a year without issue but the other morning the low beams began flickering and then shut off on the highway. I switched the highbeams and they came on and then switched back to low beams and they worked again. The next time i tried driving it the low beams will not come on but high beam works fine. I didnt find any blown fuses but was hoping someone might know before i pull the headlights out so i dont have to do that multiple times. Also idk if some bulbs are different but mine tilt the bulb to switch from high to low. Any help would be appreciated!
Old Mar 20, 2015 | 09:37 AM
tuned08ss's Avatar
Bad ballast
Old Mar 20, 2015 | 12:01 PM
jcod47's Avatar
Would it be both ballasts that are bad. I have a spare set of 55w ballasts i could swap them this weekend to test them
Old Mar 20, 2015 | 01:17 PM
DFZ24's Avatar
Both lights?
Like mentioned most likely ballasts, how is setup?
Old Mar 20, 2015 | 01:36 PM
Bass_Waves's Avatar
The harness you used is bad. Kthnxbye.
Old Mar 20, 2015 | 02:40 PM
jcod47's Avatar
Yes both headlights had the low beams stop working at same time. And its a pnp kit from ddm with the harness that connects directly to the battery power
Old Mar 20, 2015 | 03:06 PM
Bass_Waves's Avatar
ok so u have the harness. Replace that harness. It's a relay Essentially.
Old Mar 22, 2015 | 05:23 PM
jcod47's Avatar
Okay so tried switching ballasts and the new set did the same thing. Openned up the high/low relay and found it pretty well corroded and rusted. Id say thats the issue so already have a new one ordered and will be making sure no water can get into it.
Old Mar 22, 2015 | 06:24 PM
Bass_Waves's Avatar
yup. It's common. I see these issues often. Keep the harness connector facing up.
Old Jan 28, 2016 | 04:28 PM
Dre Day's Avatar
Would you be able to tell me which ones are the headlight relays? I need to check mine. My driver headlight is out.
HEATON
Oct 16, 2015 07:21 PM
patooyee
Oct 15, 2015 05:11 PM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
Slick_Nick
Sep 28, 2015 09:15 PM
