Highbeam Problem
Old Sep 13, 2008 | 08:20 PM
BlackSS/SC's Avatar
Highbeam Problem
Both of my highbeams were out so I assumed the bulbs were both blown. I replaced them and they still don't work, checked the fuses and they are ok. The blue highbeam indicator light comes on so the swicth seems to be working right. I have a wiring diagram and it says there is a seperate relay for the high & low beams. I can't find it anywhere though.
Old Sep 14, 2008 | 10:43 AM
BlackSS/SC's Avatar
any ideas?
Old Sep 15, 2008 | 10:44 AM
BlackSS/SC's Avatar
bump for info
Old Sep 15, 2008 | 10:54 AM
BlackSSNick's Avatar
it's gotta be something in the wiring, check all the wiring
Old Sep 15, 2008 | 11:30 AM
BlackSS/SC's Avatar
There is no power to the headlight, no power at the higheam fuses in the distibution box either. I just need to know where the relays for the high beams are? Can't find them anywhere. I can hear clicking when I turn on the headlights but can't isolate where it comes from. I took out all the relays out and it still clicks, sounds like under the fuse box. I've had the box out many times and never saw any under there.
Any ideas?
Old Sep 15, 2008 | 11:48 AM
alleycat58's Avatar
If you can figure this out, you will be my hero. I have the EXACT SAME PROBLEM. The dealer replaced my BCM and that seemed to help it for a short time, then it came back a year later. I have not checked relays, the dealer *claimed* to have checked them, but we all know what that usually means.
Old Sep 15, 2008 | 12:25 PM
BlackSS/SC's Avatar
I would take it to the dealer but the car is out of warranty by 1 month even though I'm under on miles
So I called the dealer and the BCM is still covered. I talked to my parts guy and there is no relay for the headlights eventhough the wiring diagram says there is. So I guess the BCM must be the problem.
Last edited by BlackSS/SC; Sep 15, 2008 at 12:25 PM. Reason: Automerged Doublepost
Old Apr 7, 2009 | 11:38 PM
massivematt's Avatar
Im having the exact problem, plus i just put an hid kit in and the brights for that wont work as well. What is a BCM???
Old Apr 8, 2009 | 12:19 AM
Nighthawk243's Avatar
BCM = Body Control Module. It is the computer used to control non-engine functions such as your lighting, flashers, signals...etc.
Old Apr 8, 2009 | 08:23 AM
alleycat58's Avatar
Yeah. I have yet to fully figure out my problem. It's either a loose connection somewhere or the BCM has gone haywire again.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
