how do i charge my capacitor
Old May 3, 2011 | 03:06 PM
kento19's Avatar
i just got a brand new stinger 1 farad capacitor. It says i need to charge it. how exactly do i do this. i don't have the bulb that it shows on the picture. is it even necessary to charge it?
Old May 3, 2011 | 03:16 PM
1AJeremyD's Avatar
You will need to use a resistor to charge it up before hand. If you google capacitor charging you will find the procedure.
Old May 3, 2011 | 03:41 PM
RoadconeTuning's Avatar
i believe the resistor is to discharge it... charging should just be hooking it up... you'd want a resistor to discharge it otherwise you'll pretty much get killed if you manage to discharge it thru you...
Old May 3, 2011 | 04:43 PM
reaper89's Avatar
i had to use my resistor to charge mine also.
Old May 4, 2011 | 03:40 AM
EmperorJJ1's Avatar
theres a resistor you can use to charge it or some rockford fosgate makes a fancy "board" to do it or you just hook it up and watch a big spark. either way
Old May 4, 2011 | 09:56 AM
gpro's Avatar
Charging it with a resistor is to prevent large amounts of in-rush current. This is the reason some systems have pre-charge circuitry. (Pre-charge - Wikipedia, the free encyclopedia)
I would probably charge it with a resistor.
You would also use a resistor, preferably on with a large heat sink, to discharge a large capacitor.
Old May 4, 2011 | 10:15 AM
YelloEye's Avatar
That's what I did with my 2f cap.
Old May 4, 2011 | 11:05 AM
kento19's Avatar
can i do damage by not charging and watching it spark? my friend told me he watched a car audio shop install his and they did it without charging it. he said there was a huge spark.
Old May 4, 2011 | 11:12 AM
YelloEye's Avatar
Read the wikipedia article above and make your own assessment. IMO though no.
Old May 6, 2011 | 01:22 AM
dillw33d's Avatar
straight dumb to not use a resistor. If you need to improvise, just about any automotive lightbulb can be used. I put subs in my ex's car, had her put on a glove and old a lightbulb while I touched the bulb in series with the battery and the cap. Worked like a champ.
Old May 8, 2011 | 04:59 AM
EmperorJJ1's Avatar
idk about straight dumb its not a big deal its not like it draws enough current to blow the fuse so whats the difference between the cap fully draining and recharging when its "connected" its not like 14v is "high volt" either
after ******* around and arcing a 220v line on a 30a breaker bullshit we had at the shop theres not a cap in the world more fucked up then that
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
