How To: Installing aftermarket door speakers
Old Dec 18, 2007 | 08:10 PM
SilverG5's Avatar
My girlfriend blew one of the door speakers in her G5 so I figured I would make a how-to since the one in the how-to section is very vauge and has no pictures. Maybe a mod will aprove and put this in the how-to section. This install is on a 2007 Pontiac G5 with power options and no pioneer factory system. I'm not going to describe how to remove the door panel since it will be different for everyone's application and there is how-to's on this.
Tools needed:
7mm socket and wrench
Dremel tool with cut-off disc
Drill and drill bit (size of bit depends on size of mounting screws that come with your speakers, make sure the bit is a size or two smaller than the screw so it can bite into the bracket)
Sandpaper
Sanding Block or block of wood
First, remove your door panel. Then remove the 7mm screw and pull out on the speaker assembly and then up, there's a metal clip that holds it in the door at the top after you remove the screw so you may need tug kinda hard. Unplug the speaker and the clip on the back of the bracket and then remove speaker from the door. Once you complete that, this is what you'll have.
The speaker and bracket are all one piece. You will have to cut the speaker out with the dremel tool. In this next pic I have circled the tabs you need to cut in half in red(look close). If your using the factory wiring and not running and amp then you can leave the one bracket that holds the clip that holds the factory wiring that you disconnected after you unplugged the speaker to remove it from the car. I did this in my install.
After you cut the speaker out this is what you'll have.
Now cut the remaining of the tabs off so you have this.
Now after removing the rest of the tabs there is a 1/4" lip on the front of the bracket that needs to be removed so the speaker will mount flush on the bracket. This is removed with the dremel also. Try to get as close as possible to the flat part but not too close, this will save you work on the next step.
Now get your sandpaper and sanding block( I used a piece of a 2x4 and 240 grit paper) and sand the lip you just removed so it is flush with the flat part of the bracket like this.
After you have sanded it completley smooth, set your speaker on the bracket and line it up where you want it. Now mark where to drill you holes on the bracket for the speaker and drill your holes. Then mount the speaker onto the bracket with the supplied screws from your speakers.
Now wire or plug in the speaker and install it in the door. Installation is the opposite of removal, make sure to check clearance of wiring and speaker with the window down. Installation is complete.
Old Jan 8, 2008 | 12:14 AM
cobaltguy88's Avatar
Nice... but u should include how to remove the door panel to make this a COMPLET how to... i understand that theres already another how to on the door panel removal, but thats just me... Lol.
Old Nov 23, 2008 | 07:20 PM
ViSiONZ's Avatar
Just saw this, good write up.
Old Apr 28, 2009 | 08:02 PM
dj4ever007's Avatar
dont they make a bracket for aftermarket speakers?
very clean install btw.
Old May 1, 2011 | 10:12 AM
Jeffs 06SS 2.4's Avatar
Very nice man! I just got on here to search for some way to get new speakers in this screwed up setup. Now I know, Thanks a million!
Old May 1, 2011 | 11:35 AM
Just in case, so everyone knows. I had to take my first speakers back and get some sony's that are thin on the back. The fat ones wont work like this.
Old May 8, 2011 | 05:16 AM
EmperorJJ1's Avatar
they were too deep?
Old May 8, 2011 | 06:02 PM
they were too deep?
No, not to deep. Actually the metal around the speaker was to fat, it would go inside the hole all the way to lay flat. I got some sony explodes that the metal frame was well within small enough to fit. They were both 6.5", the first ones were just too wide or fat.
Old May 8, 2011 | 08:16 PM
EmperorJJ1's Avatar
oh i get it the lip was too wide so the screw holes didn't work. yup yup i know what u mean now. You could have still put them in but it would have been half ghetto. i had the same dilemma with hertz speakers on a 5th gen camaro
Old May 8, 2011 | 09:58 PM
c4w18's Avatar
nice contribution.
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Sep 27, 2015 08:53 PM
