I need some help
I need some help
I have two of theese
Diamond Audio D610D2 Car Audio Sub Woofer Dual 2 Ohm Speaker
Brand: Diamond Audio
Condition: New
Frequency Response: 23-250Hz
Efficiency: 84dB
Impedance: Dual 2 Ohm
RMS Power Handling: 500 Watts
Peak Power Handling: 1000 Watts
Mounting Depth: 5.6 Inch
Mounting Diameter: 10 Inches
and my amp is
Brand: Massive Audio
Weight: 21 lbs.
Condition: New
RMS Power Output: 1500w RMS @ 1 Ohm
Peak Power Output: 3000 watts
Frequency Response: 8 Hz - 180 Hz
Input Sensitivity: 120mVrms ~ 5.0 Vrms
Ohm Load Stability: 1 ohm
Low Level Input: No
Built in Cooling Fan: No
Bass Control Knob: No
my question is can I push both of these speakers more?
Condition: New
Efficiency: 84dB
and my amp is
Weight: 21 lbs.
Condition: New
Low Level Input: No
more?
I am assuming your refering to the fact the subz handle less power than the amp puts out? Honestly that amp would push those nicely if wired correctly. Just watch the amount of bass you rrun through them. If you like rap, id sell the tens and get 12s but it should still sound ok. good luck, let me know if you need a wiring diagram. chris
The way I have my speakers wired is down to 1 ohm. Im just figuring I have 1500w split by two, so I was figuring a 2000w amp might do the trick. One thing i shold do is get new component speakers so I can turn up the bass higher then -4. the reason 'i have it low is that I dont know what the stock speakers can handle. If the stock headunit's 50w output would be too much.
Don't under estimate the Massive amps either, they are very nice and from what I have noticed have no over-heating issues. I'm still fairly new to the electronic side of things, but I have a Massive D-class 1,000.1 pushing two 10" Fosgates and man do they hit, not to mention my amp isn't even breaking a sweat.
By the way, I re-read your post. Depending on how you have them wired will depend on how much you push em without blowing the Diamond Audios. My Fosgates are set at about 3 ohms and I have no major issues as of yet, but I don't push em hard all the time either. Weather or not your Massive amp is a D-class will make a difference also, the D-class amps are specifically designed for pushing subs.
Originally Posted by peebsss
2ohm speakers can be wired down to 1 ohm. Which they are
