Ignition to radio wire...
Old Dec 16, 2009 | 02:11 AM
  #51
EmperorJJ1's Avatar
lol brick i just reread the OP and you might be right... lol whoops. im still not 100% sure what the op even is looking for
Old Dec 16, 2009 | 02:19 AM
  #52
brickloaf's Avatar
Well no one listens to anyone but you so you might want to put "remote wire is blue" in big bold letters
Old Dec 16, 2009 | 03:01 AM
  #53
EmperorJJ1's Avatar
Remote wire is blue
Old Dec 16, 2009 | 03:28 AM
  #54
brickloaf's Avatar
Remote wire is blue
X2..
Old Dec 16, 2009 | 08:47 PM
  #55
CobaltLs_14's Avatar
at first i want to hook my radio to the ignition wire but everyone said use the fuse and i did but all i git was issues so i just wired it to a switch now i need to hook my gauges up so you are telling me that its the blue or blue/white wire on the passenger side where the fuses are? can you post a pic please...
thanks
Last edited by CobaltLs_14; Dec 16, 2009 at 08:59 PM. Reason: Automerged Doublepost
Old Dec 16, 2009 | 09:55 PM
  #56
brickloaf's Avatar
thanks
its probably like a 6 inch wire coming out the BACK OF YOUR RADIO. you will need to splice a longer wire of similar gauge (probably around 20g) that will run STRAIGHT to your amp.
Old Dec 19, 2009 | 08:41 AM
  #57
EmperorJJ1's Avatar
thanks
no the problem is you have no idea wtf ur talking about and are just confusing the **** out of everyone... so lets start from scratch. what are u trying to do???
Hook up an aftermarket radio?
hook up an aftermarket amp to the stock radio?
hook up an aftermarket amp to an aftermarket radio?
Old Dec 19, 2009 | 09:04 AM
  #58
i need to hook my gauges but can not use a fuse because when i hook it up to a fuse they dont turn off and yes i tried more than one fuse...
Old Dec 19, 2009 | 11:46 AM
  #59
EmperorJJ1's Avatar
ok not including whatever tach or what not, on ur guages is there just 2 wires power and ground? or 3 ( power ground turn on)
what fuses did you try? only 2 of the 20 on the inside box might work
Old Dec 19, 2009 | 02:09 PM
  #60
brickloaf's Avatar
use the SUNROOF fuse and it WILL turn off
Old Dec 19, 2009 | 07:57 PM
  #61
SS SCHGD's Avatar
I have a Solution,
Take it to someone that knows what they are doing,
And
know what your asking for before asking a question.
By the way, if your "testing" with a door open, it's not going to work.
(and technicaly, the Sunroof fuse won't give you the Same RAP feature you had with the stock radio, as either door will turn off the radio, not just the drivers door.)
Old Dec 19, 2009 | 08:16 PM
  #62
cfcobalt's Avatar
so to piggy back on this and answer my question from another thread...
three guages...
three power wires spliced into one single power wire...
"add a line" fuse (equipped with a 20 and a 10 amp fuse) in the sunroof fuse
all three guages have power when vehicle is on but turn off when vehicle is off and door is opened...
do i have it correct?
Old Dec 20, 2009 | 01:59 PM
  #63
EmperorJJ1's Avatar
yes cfcobalt
Old Dec 21, 2009 | 08:59 AM
  #64
cfcobalt's Avatar
awesome...thanks guys
oh...and obviously the ground would be the same to a single ground source???
Old Dec 21, 2009 | 04:58 PM
  #65
EmperorJJ1's Avatar
yup u can ground it pretty much however. shouldn't make a big diffrence
Shanman
ZZ Performance
43
Aug 26, 2016 08:43 PM
The Rookie24
Jan 20, 2016 05:14 PM
agentirons
Oct 16, 2015 02:11 AM
shawnsseries
Sep 10, 2015 08:29 PM
