installing Infinitys...URGENT!!
Old Oct 23, 2005 | 12:19 AM
averagewhiteboy's Avatar
Hey guys.
Well I went over to Circuit City today and got my Infinitys out of my Cadillac. I tossed them into my trunk of the Cobalt now. I'm going to wire them tomorrow hopefully. I had to slide them in through my back seat becasue of that damn tiny opening.
lol. My set up is this: 2 Infinity 10" subs, 1 Pioneer 800 watt mono-amp, and a universal sealed felt box. Everything is already wired to the amp becasue it was done before. I also bought a new wiring kit (for up to 1000 watts) and the converter for the back of my headunit.
So basically what I need to know is this:
- How do I disconnect the OEM Pioneer sub from the amp? I'm leaving the amp in there for the speakers. I pretty much know how to remove the sub, but how do I disconnect it?
- How do I remove the OEM headunit? I'm obviously gonna need to remove it to replace the wires wit hthe converter. Is that whole converter situation plug and play?
- Since the battery is in the trunk, I just connect everything up to that...right? Will I need to get the usual GM post adapter thingy?
- Will I need a capacitor? I needed one when they were in my Cadillac becasue it was pushing the Pioneer 200 watt player, all 4 aftermarket speakers, and my sub combo described above. My lights were dimming bad. I don't want the Cobalt to lose any more power than it has to...
I'm sure there's more...but that's good enough for my thoughts now. lol. I plan on doing this tomorrow...so if you have ANY info...PLEASE POST!!!
Old Oct 23, 2005 | 12:27 AM
3fo893013L's Avatar
Score! Get some pics of that setup once your done. Sorry I would help you with that but I don't know much about car audio . Come back to me if you need performance
Old Oct 23, 2005 | 12:41 AM
Yeah. I had them in my Cadillac and they were great. They sounded amazing inside the car...and you absolutely couldn't hear a damn thing outside of the car. I'm gonna try to wire them tomorrow morning (today)...so I'll snap a few pics.
Old Oct 23, 2005 | 01:23 AM
Clmbngfrk18's Avatar
Originally Posted by averagewhiteboy
Hey guys.
if you replacing your hu your in for a suprise you new hu wont run the upgraded stereos amp you have to cut the plug and splice all the wires together on the stock amp aka bypass it and fyi no need for top post terminals you got 2 you can use it it
Old Oct 23, 2005 | 02:26 AM
02blazerx's Avatar
okay. I dont have a cobalt so ill help from what i have read and already know.
1) Unhook the speaker leads from factory amp that go to the sub.
2)Im asuming you are keeping the factory stereo and just splicing in a lineout converter for rca's? If this is right then you will need to splice the lineout converter into the stereos rear speaker leads. To remove the radio just carefully pull off the trim piece and behind you will find a few screws that hold the stereo in place.
3) No need for a post adapter.
4) Im not even going to go any further then to say that capacitors are just bandaids for a weak electrical system.
Old Oct 23, 2005 | 10:52 AM
clmbngfrk18, I never said I was going to replace my headunit. I said I needed to know how to remove it so I can hook up the wires into the back. anyone know how to do this? It's the only part that I DON'T know...
And yes, my problem with the Cadillac was probably the fact that the eletrical system power was from 1989. Enough said. lol.
So to remove the OEM sub, all I have to do is just disconnect the wire from the amp? lol. Are there just like 4 screws on the sub housing, then it just pulls away?
Old Oct 23, 2005 | 11:23 AM
dnl0407's Avatar
im not 100% shure but i dont think u even need to remove the head unit u can splice in a line down converter to the speaker wires going in to the stock sub and it equealizes the power output that is driven by the stock amp and makes it safe for rca splicing (the power levels going in the amp) and the great thing is that the battery is right there in the back then the only line u need to run is for the remote turn on wire .... u prob dont need the amp wiring kit just go to a good stero shop and ask to buy a couple of feet and u can get some decent small gauge wire anywhere so it might end up saving you 20 bucks!!! im not an expert but i think thats what i would do
Old Oct 23, 2005 | 11:26 AM
dnl0407's Avatar
pleas let me know if anything doesnt make sense or if i am wrong i havent tried this yet but i plan to some day and would like to know how right i am but at least this might lead u in a better and easier direction
Old Oct 23, 2005 | 11:49 AM
Well about the splice thing... I think that wire set up can only accomodate low wattage. I'm not sure. I'd rather be safe, then have something blow up.
*shrugs*
I'm going downstairs now to try to see what I can do. I'll be sure to snap some pics and perhaps throw together a how-to.
*thumbs up*
Old Oct 23, 2005 | 12:07 PM
mcphatty's Avatar
to remove the headunit, pull off all three of the silver trim peices off your dash. you can just tug on them to get them out, no screws. once you get the trim around the radio off, you'll see four (7mm?) screws that you'll have to remove. i believe the headunit should just slide out after that.
Old Oct 23, 2005 | 12:08 PM
T-bone's Avatar
If u have the 7 speaker check this post its got lots of info on that system https://www.cobaltss.net/forums//showthread.php?t=1939
Old Oct 23, 2005 | 05:35 PM
dnl0407's Avatar
one of the guys at our meet yesterday had an existing set up is his and he told me exactly what he did his username is vettecamaro13 maybe u can send him a message and he can tell u i am fairly confident you will not need to remove the head unit
Old Oct 23, 2005 | 05:38 PM
dnl0407's Avatar
thats what the line converter will do it makes it safe for using the powerd wires from the amp and only allows a low current for the rca's making it safe and simple no removing extra things
Old Oct 23, 2005 | 11:43 PM
Well...after a few friends joining me on my quest for some delicious bass...we got it done. I'm actually running the OEM Pioneer 8 AND my 2 Infinity 10's. It's definately sweet. I'll post up a picture or two tomorrow.
Old Oct 24, 2005 | 07:56 PM
dnl0407's Avatar
um that is a 10' in the back also
Old Oct 24, 2005 | 10:52 PM
Really? Sized up it looks like an 8". Oh well. lol.
* shrugs *
Old Oct 24, 2005 | 11:45 PM
Stealth06_SS's Avatar
okay here are my thoughts, first of all I attend Installer Institute in Daytona Beach Flordia for car electronics, so I know about stereos but haven't tinkered with my '06's system yet. About the capacitor the rule of thmb is that a cap will actually hurt a system (sound quality wise) if not used in the right settings. A cap is meant for someone who listens to alot of rock and country music (i.e. bass that doesn't hold, just has short fast beats). If you listen to alot of hip hop I would skip the cap. It released short blasts of power and the beginning of the beat will pound and the end will not be as loud. Hope that helps, secound make sure that your total power being pulled, Ii.e. amps isn't more thatn what your alternator puts out or your better save for a new one down the road. The thing you could do is by a high output alternator or get someone to build you one since an '06 doesn't have alot of parts yet. A fellow 2006 SS black auto
Old Oct 24, 2005 | 11:57 PM
Nice to see a fellow black SS.
Actually...I've noticed that I don't need a capacitor. My power supply on my Cadillac must've just been horrid. I'm not losing any lighting at all...with 3 subs!
Old Oct 25, 2005 | 12:02 AM
betterthanbad's Avatar
I've got an entire infinity speaker system with tweets and all and a JBL sub with an 800 watt gothic amp from my old Z24 but I find that this base system is not too bad for now so I'll go with the original maybe until next summer.
Old Oct 25, 2005 | 08:24 AM
mcphatty's Avatar
with my 2400w amp and the three subs, there is barely any light dimming whatsoever. the alternators on these cars must be pretty beefy
Old Oct 25, 2005 | 12:02 PM
Exactly what I was thinking. I was VERY impressed.
when I was buying my stereo for my Cadillac...I didn't really care for how the aftermarket Pioneer speakers sounded. But I figured I should opt for the Pioneer option anyway. I wanted the tweeters and stuff. I'll probably change it around later...but for now with the door tweeters and the 3 subs...it's a pretty good set up. lol.
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
