Interceptor Scan Gauge Help Please
I have been researching for a few hours now, but haven't come across my problem yet. My car is a 2006 SS/SC I have a brand new INTERCEPTOR. I removed the red jumper off the back then ran my power cable to a 12v source. Plugged it into my obd2 port. It has power and I can play with it. However when I select two parameters for example boost and knock retard no numbers come up. Went back into the menu to select scan but nothing changes.. This is my first interceptor so any help would be wonderful.
Knock parameter for our cars (at least mine) to read properly is knock retard 3.
As far as boost goes I don't know the answer, mine shows up just fine. There are a lot of parameters in the setup list that if selected won't show anything on our cars.
Another question.. what gauge did you order? The PT or CN one? 06 requires the PT model.
Just went back to play with it again picked different parameters but nothing is showing. I ordered the PT, but I haven't checked to be certain its the correct product. Maybe I should check that out.
