invisicord install on 2010 ss/tc
Old Mar 8, 2010 | 06:53 PM
RiceCop's Avatar
Anyone install one? There's no info on the web about installing one on our cars. I can't figure the damn thing out.
Old Mar 8, 2010 | 07:01 PM
Nighthawk243's Avatar
Do you have a powered mirror? It is supposed to tap into the mirror connector.
Old Mar 8, 2010 | 07:03 PM
northvibe's Avatar
Guidelines on Using a Voltmeter to Locate Power and Ground
- First set your voltmeter to the continuity setting (should beep when you touch the red and black probes together, telling you they are shorted)
- Find a ground on the car somewhere, like a bolt under the dash, or a metal cross member.
- Put the black probe on that ground, and touch the back of each exposed wire connector in the mirror harness with the red probe.
- For each wire that beeps, that means that wire is grounded. Turn the inition to the on position, then back to off, and make sure it beeps regardless of ignition position.
- Put the voltmeter into VDC mode, to measure DC volts, turn the ignition to the on position.
- Put the black probe on the ground wire found in #4.
- Touch each of the wires in that harness with the red probe, and note which one(s) gives you +12-14 volts, turn the ignition off to verify that the volt readings go down to zero or close to zero.
-That should define which two ports in that harness into which you would plug the Invisicord, the black Invisicord heat shrink connector into #4 above, and the yellow to #7.
Old Mar 8, 2010 | 10:02 PM
RiceCop's Avatar
ok thanks. I was trying to take the lazy way out and see if anyone had installed one yet that could tell me which ones to use. Guess I'll have to mess with it tomorrow.
Old Mar 8, 2010 | 10:35 PM
I used a fuse tap and just ran the wires under the dash and up the pillar. Much easier and cheaper than messing with a multimeter
Old Mar 9, 2010 | 12:53 AM
EmperorJJ1's Avatar
wow that looks like a stupid contraption. hardwiring the radar detector is fairly easy
Old May 5, 2010 | 01:11 AM
mr84monte's Avatar
Did you figure it out yet?
Old May 25, 2010 | 09:45 PM
mr84monte's Avatar
In case anyone goes to search this, this was my finding:
According to the manual the power going to the mirror (09 Cobalt) is only 10v. I then confirmed this with a multimeter. I emailed invisicord with my findings and they confirmed this will not work (at least with an Escort 9500ix), and said I could get a longer one to run somewhere else, so tonight I stopped and picked of a smartcord to wire to the fuse panel.
Old May 25, 2010 | 11:22 PM
EmperorJJ1's Avatar
i know not everyone has access to the tools that i do but it really isnt hard just soldering to the cig lighter plug and hardwiring it yourself
Jan 12, 2016 12:01 AM
justinchinn
Oct 2, 2015 12:18 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
