JRANGER Starts His Fiberglass Sub Box
#153
Its just fiberglass. Essentially the best thing to do is cut the back piece o wood all the way across then you just start fiberglassing it while its in your trunk. Look at the first page and you can see where I was doing this. You put 2 - 3 layers on while its in your trunk and let it set. Then you remove it from the trunk and add more layers to the inside of where you molded it to your trunk
#154
#155
well yea it will adhere and you wont get it off. If you looked at the pics on page one you will notice blue tape all over where I was doing fiberglass. I simply bought blue painters tape and put 2 or 3 layers of tape on the carpet. That way it will pull right off the carpet. So yea dont fiberglass to the carpet
#156
Looking good so far man!!!
What I'm wondering is, after you put in a custom fit enclosure like this, what happens when you need to get to the spare wheel or the battery?
I might be ready to build my own fiberglass box in around 5 years!
Hope you guys are around to mentor me at that time :P :P
Not kidding, I'm trying to read up on it as much as possible.
And its expensive, so I don't wanna f**k up.
#157
well it depends on how big you build the box.. Im pretty sure impulse can get to his still and I think I will still be able to get to mine pretty easily too. I just have to break the boarding under the carpet so i can bend it up in front of the sub box As far as cost I am thinking I have only put like $200 into this as far as supplies...so its not incredibly expensive but it takes alot of time. What cost alot is if you need tools, I spent about $200 on tools but that is only because I didnt listen to impulse and start witha Router and bought a rotozip first...
#158
Another good trick so you don't have to find with peeling the painters tape off is use aluminum foil. Tape down (really good taped down) large pieces of aluminum foil. It peels right off the foil.
I'm gunna do mine in the rear wheel well areas as soon as it's warm enough here to fiberglass it in the car completely. It's still to cold for the glass to cure overnight and I can't bring the resin into my apartment. Neighbors complain and the cats try to eat it... no good.
Looks great though. You gunna paint or carpet it?
#159
Im going to paint it Metalic Blue Flake....I will either carpet the back or just get some thing board to carpet and put over the back for when i pull down the back seats I will more then likely be able to start painting next week.
I just realized in my old setup in my mustang I had about the same volume and the box was not ported..It sounded awesome......Do you think it would still sound real good without porting it emperor? I might just paint the box and give it a try and if I dont like the sound go ahead and port it since I bought the ports
#160
I would say you would get a tighter bass response with leaving it sealed. Porting it in my opinion would be a big hassle for a gain in db's.
What do you want out of the system? Volume (Loudness) or crisp tight bass?
#161
Well I like it loud and getting good response...The thing is the specs of the sub of r a sealed box are max of 1.25 cu ft. So 3 cu ft for both. My box is 4 and Im thinking I will get good response and alot of sound from them. I want to bump!!!!!!
#162
I think they would sound alright either way. It will definately hit hard.
I'm using 2 10" JL Audio W3v2s and I'm keeping mine sealed. I had loud once and don't ever need a system to be that loud again.
#164
i have those exact subs...and let me tell you...f'in fantastic subs...tight as **** and they pound. i got them hooked up to the JL A1800 gettin 500 watts rms each. It's still untuned bc I can't find my dmm. Gain is turned all the way down pretty much atm and they still hit. mine is sealed to spec.
#165
I think mine might be a little smaller than specs as like i said I plan on glassing the sides of the trunk so I can still use the trunk space for golf clubs or the occasional need to fold the seats down and transport something longer in size.
I had 2 12" in the powersledge box before and with 200 watts a piece they pounded like crazy. My LOUD system was 2 12" kicker L5s in a massive ported box with 2 Kicker 1000.1s. Hit like 149-151dbs depending on the mic. My dad and I tested it on the street and you could hear me driving down the road, over 4.5 blocks away.
#167
#170
He speaks the truth. With my very loud and clear system, very sound dampened, with the windows rolled up you can only hear it if you are near the glass. With the windows down you can only hear it if you are by the open window. Behind or infront of the car its nearly silent.
In the car is insane! Hits so hard it hurts.
#172
#174
WOW! You couldn't be more wrong! Unless you have some sort of damping material in your trunk, you have no idea how good your subs are capable of sounding! In fact, I would say someone with a single sub setup with a decent amount of damping will get just as much punch as someone with 2 of the same subs and no damping material. As stated on a box of Dynamat Xtreme, "Dynamat creates a sonic barrier restoring 3,6, or even 12dB of lost dynamic range. Gaining 3dB is like doubling your effective amplifier power. And that means YOU HEAR MORE MUSIC!" If anything, you wasted your money on that second sub and all that fiberglass, carbon fiber and resin! Although it does look really good. LOL
#175
