just ordered JL w1
just ordered JL w1
yeah so i just ordered a 10" JL w1 from crutchfield.
im anxious to get it hooked up, mainly looking forward to buildin the box.
anyone else have this sub that have built there own box? how many cubic ft did you make it?
This is the owners manual for the 10w1
In it they give you exact spects on how the box should be made, ported or sealed.
A copy of this will be in the box with your sub
http://mobile.jlaudio.com/pdfs/8551.pdf
What amp are you going to have running it
and im gettin an alpine M500 amp to power it
500w x 1 @ 2ohms
300w x 1 @ 4ohms
where do i get the polyester stuffing?
the w1 series does not handle that much power.. i would only drive it 50watts over the rms.. jl posts a range chart which is awesome. if it is in black it will void the warranty. tthe best thing to do is keep everything distortion free. jl can take a lot more then the rms if it is distortion freeee. good buy.. i think the new tw5 is sooo hot.. ill trade someone a 13w7 for one
Since he will only be running 1sub the amp will be running at 4 ohms mono.
So with a 4 ohm rating of 300 watts that Alpine seems to line up perfect numbers wise.
I would not run the amp at full tilt though, 75-80 % should run that sub nice without over working the amp
BTW-You can get the polyester in the fabrics section at Walmart
The sub has a continuous power rating of 300 watts.
and do you just fill the whole box with it? and what exactly does it do?
