LNF need clutch expert and opinions
Old Sep 3, 2015 | 02:47 PM
SS_2009_TC's Avatar
Well i need a new clutch seen alot of good thingS on the GMPP one from ced BUT my main concern is what do i exactly need to order there is like 3 kit avaliable?
Should i order just the pressure plate and clutch disk with the Tob and add my flywheel resurfaced or it is better to upgrade or get a new one?
Clutch only slip when wot in every gear at 3k momentaly but still slips car has 72000 by now and trifecta tuned since feb 2015.
This is an open thread so what do you suggest? I love the stock pedal feel of the clutch. But dont sant to retouch the clutch due to a slipping one.
Thanks
Old Sep 3, 2015 | 02:50 PM
no_ss's Avatar
Since you'll be replacing the clutch you might as well make everything else just as reliable as your new clutch will be and give the clutch time to break in when you install it!
Dipped_Cobalt's Avatar
get the infamous james rakes one
jk, mines stock, ill let others with experience chime in
Old Sep 3, 2015 | 02:52 PM
If you're going to replace the clutch do everything.
Also stop going WOT below 3k in any gear other than 1st
Old Sep 3, 2015 | 03:20 PM
blueLNFftw's Avatar
Ecotec LSJ Clutch Upgrade Kit 19212712
buy a new flywheel from ZZP.
do not machine your OEM one.
2 quarts of 88862472 OEM F35 fluid for the trans. Amazon has it cheapest. DO NOT USE ANYTHING ELSE.
Old Sep 3, 2015 | 04:15 PM
That's what you need ^
Old Sep 3, 2015 | 05:19 PM
Omiotek's Avatar
You can use redline mt-90 as a supplement for the oem stuff.
Like everyone said change the pressure plate, clutch disk, flywheel, tob, clutch pipe and distribution block.
Old Sep 3, 2015 | 08:06 PM
SS_2009_TC's Avatar
I NEVER floor it below 3k
As for the flywheel you recomand the fidanza right?
Old Sep 3, 2015 | 08:08 PM
I'm sure they will say oem flywheel
Old Sep 3, 2015 | 08:10 PM
sc4door's Avatar
Clitch only slip when wot in every gear at 3k momentaly but still slips car has 72000 by now and trifecta tuned since feb 2015.
Thanks
These 2 statements slightly contradict each other
Old Sep 3, 2015 | 08:26 PM
SS_2009_TC's Avatar
I was meaning when i floor it at 3k then momentaly the clutch slips when clutch fully depressed and i hit the gas pedal sorry that was clear to me sorry for my poor english.
Old Sep 3, 2015 | 08:30 PM
STOP DOING THAT. Minimum 3.5k for WOT
Old Sep 3, 2015 | 08:35 PM
Powell Race Parts's Avatar
machine flywheel no problem just got to do the step
or buy new. They went up in price. LSJ/LNF same flywheel
GMPP the best.
CED best kits, best service, decent price cheap, shipping.
good installers? hard to find it seems
Old Sep 3, 2015 | 11:17 PM
KMO43's Avatar
I am running 480+hp i have a southbend stg4 plate on a stock disk and its the best setup ever! Hasnt slipped and drives like stock. My brother who hated my stg4 disk says its the ****
Old Sep 4, 2015 | 03:34 AM
LNFwagonSS's Avatar
Really? At what depth will shimming be needed to avoid TOB overextension?
Old Sep 4, 2015 | 03:43 AM
KMO43's Avatar
To match wear plus machine amount to get back to the stock ratio
Old Sep 4, 2015 | 06:31 AM
reybalt's Avatar
Get ahold of Matthew Rom. on Facebook. Great deals on the clutch you want.
Old Sep 4, 2015 | 08:31 AM
SS_2009_TC's Avatar
So far so good clutch must be glazed or something with my trifecta selec tune activated and shifting at 4k in all gear there is no slip at all but i have to match my gear to this new rpm.
Anyone noticed when shifting rapidly for example from 1st to 2nd at high rpm i am hearing a quick quick sound no clutch slip and no wheel spinning...
Have an idea?
Old Sep 4, 2015 | 10:48 AM
breds2k's Avatar
Originally Posted by reybalt
Get ahold of Matthew Rominowski. on Facebook. Great deals on the clutch you want.
THIS
Matt sent me a 1 paypal invoice with every single item needed for clutch replacement, fluid, flywheel bolts and everything INCLUDING GMPP clutch which I highly recommend for a daily driver on pump gas that's not on a brutal tune. Only thing needed was a flywheel because they are $4-600 from GM and still under $210 for ZZP.
And he gives better pricing than retail if you mention either forum/fb group ect.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
