kinetic hc800
Old Nov 28, 2011 | 08:48 PM
chitala383's Avatar
kinetic hc800
Can the kinetic hc800 be used as a replacement battery, or is it strictly a power cell for audio equipment?
Old Nov 28, 2011 | 09:04 PM
chitala383's Avatar
I thought i remember somebody doing that but the owners manual says that's only for the 1400 and up.
Old Nov 29, 2011 | 03:10 AM
EmperorJJ1's Avatar
it can but it is a small battery. u would need to keep a close eye and make sure it doesnt go dead often
Old Nov 29, 2011 | 08:28 AM
chitala383's Avatar
So I'm probably better off picking up another stock battery and worrying the kinetic to that how the manual says then?
Old Nov 29, 2011 | 11:26 AM
EmperorJJ1's Avatar
huh?
Old Nov 29, 2011 | 12:16 PM
chitala383's Avatar
Wiring, not worrying. Stupid Swype. The manual shows to wire the hc800 to your battery and then power your amp from that i believe. I looked at it quick last night and now i can't remember exactly what it showed
Old Nov 29, 2011 | 12:50 PM
-TurboSS-'s Avatar
Look into XS bats too... They may have a higher current one that'll fit for a starter. Lots of sales on too.
Old Nov 29, 2011 | 06:44 PM
chitala383's Avatar
I think I'm going to get the kinetic hc1400 to replace my starter battery. If i wire both the 1400 and 800 parallel what size inline fuse should i use between them?
Old Nov 29, 2011 | 08:42 PM
-TurboSS-'s Avatar
I think I had a 300 between mine.
Old Nov 29, 2011 | 11:22 PM
chitala383's Avatar
Anyone else? Emp, where did u go? I'm looking for your input here, haha
Old Nov 29, 2011 | 11:49 PM
EmperorJJ1's Avatar
went to work... if u put the batteries like side by side then dont even worry about a fuse. its also "best" to keep the same size/type battery when using multiples.
do u already have the 800? and what system if any do u have (or additional electronics)
Old Nov 29, 2011 | 11:57 PM
chitala383's Avatar
I already have the 800, as of right now I'm only running a 600 watt amp and sub, pioneer 4100 head unit, and the rest stock. I do plan on upgrading the rest if the speakers in the near future though. Just not sure exactly what I'll be getting
Old Nov 29, 2011 | 11:59 PM
EmperorJJ1's Avatar
ok that makes sense then ya i def wouldnt use only the 800 and mixing agm and lead acid (liek stock) batterys is bad too. so u should be ok with the 1400 and 800 combo
when wiring the batteries id suggest hooking the amp power wire to the 1400 and then hooking the stock alt bcm ect power wire to the 800
Old Nov 30, 2011 | 06:39 AM
chitala383's Avatar
What's the reasoning behind doing it that way exactly?
Old Nov 30, 2011 | 01:20 PM
EmperorJJ1's Avatar
the only "issue" with using a small batt and a bigger batt together is the small batt drains faster and ur only as good as ur weakest link. if the small batt stays drained and develops a memory then it is not only ruined but holds the whole setup down. so if u put the charging wire on the smaller battery and the amp power on the bigger one the current has to go from the 800 to the 1400 then to the amp. so less likely to mess up the 800 by not keeping it charged
Old Nov 30, 2011 | 01:55 PM
chitala383's Avatar
I guess that makes sense. Thanks emp, i knew i could count on u.
elite_Cyborg
Stuff
Jun 22, 2009 01:28 PM
Brandon22685
Jun 21, 2009 08:11 PM
