LEDs in map lights keep glowing
So I swapped my trunk light, liscence plate light, reverse lights, and map lights with white LEDs. Everything seems fine except after the map lights dim down, they glow just enough to illuminate the lenses on the map lights. And they continue to glow for days without getting in the car. They haven't drained the battery, yet. The car isn't my daily driver so sometimes it could be weeks between times I drive it. Wondering if anyone else has had this issue?
Would you happen to know how many ohm resistor and can I just attach it across the led? Or would that create too much heat in the rear view mirror?
Get these bulbs and even though they say oversize they will fit as I have them on my car and I have no issues with the dimming at all, they completely shut off with no dimming once door is closed like the stock 194 bulbs.
194 LED Bulb - 15 SMD LED Wedge Base Tower | LED Replacement Bulbs for Cars | 12v | Super Bright LEDs
z28addiction
Sep 28, 2015 12:03 AM
