LEDs in map lights keep glowing
Old May 11, 2014 | 01:40 PM
NihontoSS's Avatar
So I swapped my trunk light, liscence plate light, reverse lights, and map lights with white LEDs. Everything seems fine except after the map lights dim down, they glow just enough to illuminate the lenses on the map lights. And they continue to glow for days without getting in the car. They haven't drained the battery, yet. The car isn't my daily driver so sometimes it could be weeks between times I drive it. Wondering if anyone else has had this issue?
Old May 11, 2014 | 01:52 PM
jcobaltss's Avatar
Don't worry about it won't hurt anything. Mine have been doing that for 2 months now and no problem yet
Old May 11, 2014 | 01:57 PM
chevygirl2006's Avatar
This is asked so much on here. A simple search you would find out why. It's because the led needs a resistor.
But like said above, it won't cause harm.
Old May 11, 2014 | 04:22 PM
NihontoSS's Avatar
Would you happen to know how many ohm resistor and can I just attach it across the led? Or would that create too much heat in the rear view mirror?
Old May 11, 2014 | 04:33 PM
1 in each led. 1ohm. You can get a pack at radio shack for like $1.60. It needs to be soldered.
Old May 11, 2014 | 07:04 PM
efren6057's Avatar
Get these bulbs and even though they say oversize they will fit as I have them on my car and I have no issues with the dimming at all, they completely shut off with no dimming once door is closed like the stock 194 bulbs.
194 LED Bulb - 15 SMD LED Wedge Base Tower | LED Replacement Bulbs for Cars | 12v | Super Bright LEDs
Old May 11, 2014 | 07:35 PM
Ya you can buy LEDs that already have resistors.
DarrenGC
Dec 24, 2021 01:55 PM
dennis69
Oct 20, 2015 04:49 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
z28addiction
Sep 28, 2015 12:03 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
