left turn signal problems help
Old Nov 21, 2012 | 09:52 PM
The Rookie24's Avatar
so i just recently bought a 05 ss i just installed 3rd gen projector hid headlights and the left turn signal bulb wont go on when i start the car it only goes on when i hit the turn signal also the the turn signal doesn't click into place when i do the left turn signal the rights is fine i wired the headlights the same exact way so i don't get it im not driveing this car currenly it jus sits in the garage when i bought it i cant say for sure but im pretty sure the turn signal didnt lock into place before the headlight swap thanks for the help
Old Nov 23, 2012 | 03:01 PM
EmperorJJ1's Avatar
are the turn signal bulbs led?
Old Nov 23, 2012 | 03:16 PM
mrader88's Avatar
^^^ if they are led take it out and turn it around the wore connector may be backwards to work, mu switchback led bulbs did that too
If not i believe stock bulbs are dual filiment so maybe one burnt out? Try another bulb
Old Nov 23, 2012 | 04:36 PM
its not led jus regular bulb and ok i will try that but does that explain why the turn signal lever dosent lock into place
Old Nov 23, 2012 | 06:03 PM
mrader88's Avatar
On the steering column? Its probably broken off
Old Nov 23, 2012 | 07:00 PM
yea on the steering column the right one locks into place the left does not
Old Nov 23, 2012 | 07:06 PM
mrader88's Avatar
The only time i ever had issues like this was on my old wrangler, and i replaced the whole turn signal assembly and it worked again tere was something broken on it. May be the same issue with urs
Old Nov 24, 2012 | 01:49 AM
EmperorJJ1's Avatar
ya sounds like an issue with the assembly
Old Nov 24, 2012 | 03:30 AM
serega12's Avatar
I'd start with replacing the turn signal stock... That'd most likely fix the problem with it not locking.
Then I'd check the bulb and the plugs going to the headlight assembly to make sure none of the wires get broken/pulled out of sockets during installation. Maybe reuse your stock wire harness (not the one that came with projector headlights)?
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 04:49 PM
roth
Sep 26, 2015 12:16 PM
