Looking For iPod Adapter
Old Oct 26, 2009 | 10:53 AM
Navarch's Avatar
Two questions:
1) Where is the best place to get an iPod adapter?
2) Best product?
Thanks.
Old Oct 27, 2009 | 10:37 AM
Navarch's Avatar
Old Oct 27, 2009 | 10:42 AM
Pyros777's Avatar
What year is your car? Did it come equipped with XM? GM makes one for 07+ radios that came with XM.
http://www.gm.com/vehicles/parts/ipo...FAQs+JAN08.pdf
Old Oct 27, 2009 | 10:47 AM
Navarch's Avatar
Its for my fiancee.... she has a 2006 ford focus ZX5 SES. No satalite radio.
Old Oct 28, 2009 | 06:00 AM
Navarch's Avatar
Old Oct 28, 2009 | 10:40 AM
animodarnoc's Avatar
go to your local future shop and pick this up [iSimple iPod FM Transmitters (IS76RC)] -129.99
it is an fm modulator... it connects into your vehicle through the vehicles antennas... when the modulator is turned on it blocks out all outside frequencies so that you are not competing with other radio stations... therefor no static... overall all they are the best out there right now... plus it will charge your ipod... and on the module it has an audio input left and white... so if you buy a "Y" cable or stereo cable you can connect any device with a 3.5mm headphone/speaker output...
Old Oct 28, 2009 | 10:52 AM
umrdyldo's Avatar
FM transmitters are complete crap. Sorry if you think otherwise. You are losing a ton of quality by using them and the bleed through it terrible.
Might be your only option though.
We don't much about Fords around here though so might look elsewhere.
Old Oct 28, 2009 | 11:20 AM
an fm modulator is completely different then an fm transmitter... COMPLETELY... like i said above... the fm modulator integrates into your car system through the antennas... meaning its hard wired right in... when it is turned on you block out all outside fm frquencies essentially turning off your antenna therefore you do not get any bleed through since no outside frequencies can hit your speaker...
fm transmitters broadcast your music at an fm frequency with the antenna on allowing that frequency along with many other to be picked up by your radio... causing static... COMPLETELY different then an fm modulator...
now of course the best way to integrate an ipod into a car system with the best sound quality in mind would be to replace the HU with an aftermarket with either usb, aux or ipod 30pin adapter... but that also costs more then an fm MODULATOR... the least expensive route would be the MODULATOR...
and i have seen plenty of them installed and they have been great... no problems... no static no bleed through....
hacadacalopolis
Oct 28, 2015 06:09 PM
chefhhr
Oct 26, 2015 10:36 PM
How to Guide
57
Oct 15, 2015 11:56 AM
Turbo6
Sep 24, 2015 04:15 PM
