looking for small amp sugestions?
Old Nov 14, 2008 | 05:30 AM
sptrdss's Avatar
I have the pioneer 7 speaker system in my 09 with the factory radio,have upgraded the door and rear deck speakers to infinity's and changed the rear sub speaker to an alpine but want to put a small amp on only the sub to give it a lil more kick.I'm looking for possible suggestions on the amp and how I would go about wiring it in to the sub?thanks
Old Nov 14, 2008 | 10:04 PM
SS SCHGD's Avatar
Any of the class D's would be great, maybe one of the Alpine ones. (there tiny) or one of the Blaupunkt amps. If it has a High input you can use that, otherwise you'll need a line output converter.
Old Nov 14, 2008 | 11:20 PM
tony2toness/sc's Avatar
a class d might be strong depending what kind of woofer lol
Old Nov 15, 2008 | 12:22 AM
SS SCHGD's Avatar
class D's come in all amounts of power, just ussually in a smaller form.
Old Nov 15, 2008 | 02:10 AM
EmperorJJ1's Avatar
x2 class d is just diffrent technology. more expensive to make then class a/b and run mor efficient. only downside is they mainly only work as sub amps. Check the alpine to see what ohms its running and that will let you know if u need a 2 channel (4 ohm) or mono block (2 ohm)
Old Nov 15, 2008 | 05:16 AM
sptrdss's Avatar
my Alpine sub is a 2 ohm dual voice coil so I guess it would be a mono?
Old Nov 16, 2008 | 01:33 AM
SS SCHGD's Avatar
I take it that you mean dual 2 ohm voice coil (which would make it 1 ohm or 4 ohm capable) and whats the recomended RMS wattage for the sub?
Old Nov 16, 2008 | 09:06 AM
sptrdss's Avatar
the sub I have is an Alpine SWS-1023D rated at 50-300w RMS from what the spec sheet shows.Any suggestions as to an amp for it?somebody recomended a Orion Cobalt CO600.2 amp,what do you guys think?Apparently I will not need a line out converter with this amp??
The Rookie24
Jan 20, 2016 05:14 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
MrInsanityWolf
Sep 29, 2015 04:54 PM
c_m_shooter
Sep 27, 2015 04:40 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
