Looking for the VSS wire.
Old Jul 1, 2008 | 10:29 PM
BCM's Avatar
BCM
I'm trying to tap into the VSS wire for my Pioneer AVIC-D3, I've read that it can be tapped through the BCM C2 gray wire at pin 62, but I found 2 gray wires and I don't know which one to tap into. Here's a pic of what I'm talking about
Old Jul 1, 2008 | 11:48 PM
Installer1's Avatar
I thought it was pin 61...same pin as cruise signal.
You are going to have to pop off the blue top cover, so you can get to the correct wire by pin number.
The pins are labeled
Old Apr 2, 2011 | 10:57 AM
CanadianCobalt's Avatar
I HATE to bump an old thread, but this is what searching gets you .
I popped off the blue cover, but found the pins un labeled, can anyone teach me how to read pins?
Joel
Old Apr 2, 2011 | 11:07 AM
SlowBalt_06's Avatar
I thought u had to get the wire from the ecu itself
Old Apr 2, 2011 | 11:55 AM
No, you can use the ECU, the one on the BCM or the less reliable one behind the speedo. I'm shooting for this one.
Joel
Old Apr 2, 2011 | 11:57 AM
google avic 411 they are super helpful there
Old Apr 2, 2011 | 12:03 PM
Thanks 07MetallicSC, that's where I originally got it from. Great site. The only problem is I don't know how to read the pins, it's supposed to be pin 61 in the vertical BCM connector in the kick panel but I'm not sure which one that is.
Do I look at it and count from rows from the left?
as in -
1 2 3 4 5
6 7 8 9 10
Eg for a 10 pin connector? Google hasn't helped me a ton here and I can't find a BCM Pinout diagram anywhere for the cobalt.
Joel
Old Apr 2, 2011 | 12:10 PM
msg this guy on here, REALLY knows his stuff. if he cant help you out id sell my car.
EmperorJJ1
Old Apr 2, 2011 | 04:26 PM
FITZ07's Avatar
as in -
1 2 3 4 5
6 7 8 9 10
Joel
If your looking at the pins themselves ( the side that plugs in) with the long white tab to left, the pins should count 55 -72 on the top row from right to left. Pin 61 is grey and should be next to a white/ Black wire in pin 62. Or you can go to the "how to" threads on the site and look at the one titled adding cruise and stereo controls and it will show you a pic thats numbered
Old Apr 2, 2011 | 05:06 PM
TommyP's Avatar
AWD > FWD
You shouldn't need the VSS wire. I never hooked mine up and everything works fine.
cobaltbluechaser
Jun 10, 2009 02:10 AM
19transam81
Mar 7, 2008 02:11 PM
SS33
Jan 31, 2008 09:58 PM
PolishPauL
Jul 29, 2007 06:15 PM
Piercingpsycho
Aug 2, 2006 07:19 AM
