Loud Door Chime
Old Nov 15, 2009 | 07:16 PM
Ducky22287's Avatar
Loud Door Chime
Ok, so I put in a new pioneer head unit in my car and used the GMOS-LAN-04 wiring harness cause it's a 2007 without onstar but pioneer sound system. The problem is the door chime is loud and so is the blinker sound, anyway to get around that?
Old Nov 15, 2009 | 07:20 PM
KillerBee's Avatar
Humm this happened to my car when the dealer replaced my factory radio, they didnt have the software to turn it down when they replaced the software so they turned it off lol!
Old Nov 15, 2009 | 07:24 PM
Black08SSTC's Avatar
on the harness there is a box with a philips screw head in there. turn in counter clockwise to lower the doorchimes and blinker. i had the same problem, easy fix though
Old Nov 15, 2009 | 08:52 PM
Spun's Avatar
Actually the blinker volume is supposed to be controlled through the jumpers that are on the other side of the dial.
However when I changed mine it didn't do sh*t, turning the screw on the side of the box did so that goes to show you what good comes from reading the instructions.
Carefull how far down you turn that screw, it also controls the over all volume for the stereo.
Old Aug 25, 2010 | 04:02 PM
RYRO14's Avatar
Where is the harness on the back of the radio?
Old Aug 25, 2010 | 04:48 PM
yes, it plugs into the aftermarket radio, GM-LAN-04 is what i have
Old Aug 25, 2010 | 05:34 PM
RYRO14's Avatar
Will it adjust the chime with the factory radio? Is Gm LAN 4 factory?
Old Aug 25, 2010 | 08:06 PM
Piston_Head's Avatar
No. The adapter harness is only used when installing an aftermarket radio.
biniecki
Oct 25, 2015 02:23 PM
OrangeK
Sep 20, 2015 03:02 AM
Highgross89
20
Sep 11, 2015 03:24 PM
Infamous SC/SS
Sep 4, 2015 05:33 PM
Adam144
Sep 3, 2015 07:48 PM
