metal bracket behind stereo
Old Apr 28, 2009 | 08:01 PM
madlion's Avatar
what the hell was gm thinking???????????????? that damn metal bracket is going to be the death of me.. must it be cut????i need like 1.5 inches more of clearance. damn it to hell.can i beat it in with a hammer?? whats the best way to deal with this issue?
got it.. cut plastic piece after removing the bolts then remove bracket.. i still am unsure where the bracket screws are at..
Old Apr 29, 2009 | 12:20 AM
EmperorJJ1's Avatar
the screws are on the far left and far right. there's 3-4 7mm bolts
Old Apr 29, 2009 | 01:05 AM
Spun's Avatar
Wear Gloves
Old Apr 29, 2009 | 04:51 PM
madlion's Avatar
yeah i had 3 bolts 2 left 1 right. i bent the crap out of the bar to help me get to them. just call me bloody knux i wore no gloves. lord have mercy.. that was the hardest install i have ever done aside from an install or two without a wiring harness. although now i could do it in 20 minutes. what the hell is up with these new cars. they really dont want you to swap out the stock stereo.
also if you drop a bolt or something while performing this surgery the best way to find it is to remove the cup holders, it should be in there somewhere! now i have crossovers YAY!!!!!!!!!!!
Old Apr 29, 2009 | 05:17 PM
PolishPauL's Avatar
Are u talking about the metal bracket on the left and right sides with a hole in each one? It would be good to get rid of them because my AVIC-F700 barely has room to breathe.
Old Apr 30, 2009 | 01:48 AM
EmperorJJ1's Avatar
no i wouldn't mess with those. ur hu shouldn't need to breathe much
they are talking about the metal bracket in the back that prevents some units from fitting flush. its used to hold the back of the stock radio in
Old Apr 30, 2009 | 10:17 AM
PolishPauL's Avatar
O ok thanks. Il take a look to see if mine is still there. Maybe my installer already removed it.
Old May 2, 2009 | 08:32 AM
yetiguy11's Avatar
If you remove the bracket....you would also have to cut the plastic for the console that is bolted to it using 3 screws.
Does it affect the integrity of the console or dash too much with it removed? I could really benifit from rippin it out.
Old May 3, 2009 | 12:59 AM
EmperorJJ1's Avatar
yes the plastic must be removed to get rid of the metal bracket
Old May 3, 2009 | 01:05 AM
NWAE Cobalt's Avatar
the shop i had do the install just cut it
Old May 4, 2009 | 01:15 AM
madlion's Avatar
nope it doesnt affect the integrity.. you cant see it at all.
SmitBag
Sep 7, 2016 08:05 AM
Spanky's Monkey
Mar 7, 2016 06:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
Slick_Nick
Sep 28, 2015 09:15 PM
