Molded sub box
Old Nov 19, 2006 | 09:15 PM
2fastforyou's Avatar
Molded sub box
How do i make one of those custom molded sub boxes and what material do i need to make it?
Old Nov 19, 2006 | 09:18 PM
HackAbuse's Avatar
Fiberglass
Old Nov 19, 2006 | 09:20 PM
liquid fiberglass?
Old Nov 19, 2006 | 09:28 PM
sorry im very unexperienced at doing this but can i mold it into place like playdough and what material do i need to make the molding
Old Nov 20, 2006 | 04:06 PM
06Pursuit's Avatar
usualy moulded sub enclosers are made of fiberglass which is made in a specialy constructed mold. Think of it as a negative of ur trunk. They fill it with fiberglass, not liquid they usualy spray it in. Then they pull it out and it will look like what ever you wanted it to look like lol. Preaty expensive prosess unless you know someone in the buisness
Old Nov 20, 2006 | 04:09 PM
JRANGER's Avatar
or are willing to put in some hours
Old Nov 20, 2006 | 04:13 PM
JCswoosher2's Avatar
yeah for real. a good bit.
Old Nov 20, 2006 | 05:43 PM
id kinda rather try it myself moneys not the problem its just the user lol. wish they had a how to on it
Old Nov 20, 2006 | 06:05 PM
xspyder85x's Avatar
fiberglass isnt cheap since you need a buch of layers.
Old Nov 20, 2006 | 06:07 PM
mkulrey13's Avatar
There is a link somewhere for a perfect fiberglassing how-to jsut search. i plan on doing it over the winter
Old Nov 21, 2006 | 01:09 AM
mikess06's Avatar
i can't find the link anyone know where it is??
Old Nov 21, 2006 | 12:58 PM
man i need to find that
Old Nov 21, 2006 | 01:31 PM
JRANGER's Avatar
here I found this
http://chris.pfharlock.com/glass/
Old Nov 21, 2006 | 02:26 PM
impulseballer's Avatar
thatz the link i was gonna post. Keep in mind if your looking to do a design that cannot be made by simply stretching "fleece" like he did. The best thing to use as a "mold" or template is a large size block of i forget the name but it's like scultable styrofoam. You can sand it and cut it to your shape you desire and fiberglass on top of it.
Old Nov 21, 2006 | 05:18 PM
awesome guys thanks for the help
Old Nov 22, 2006 | 04:06 AM
ted5986's Avatar
it actually is easier to use material and strech it over the rings for your mold. your mold is not sprayed in it is brushed in. first tape off you trunk with blue tape. then lay down a layer of aluminum foil. polace tape over any overlapps you have. mix up some resin and mekp (hardener) brush on the resin. precut many pieces of glass chop mat. dont use cloth cause it will tak you forever. it is far too thin. dab the resin through the mat until it is saturated. (do not over saturate). then repeat. do about 2-3 layers then let it cure. then a few more. pop the mold out of your trunk once the mold is dry. mount your sub rings. stretch fabric over rings. follow same routine as before with glass and resin.
this is a very basic tutorial.
need more helpo go to
www.fiberglassforums.com
they will help you
Old Nov 22, 2006 | 05:30 AM
InfinityzeN's Avatar
Instead of molding the whole box, get a custom made box that fits where you want it and have a sheet of fiberglass made that covers the box and goes to about 1/2" out of sight all the way around. Like taking the stop subbox and putting a sheet in front of it with a cut out of the sub. You can put in the box, the sheet, then mount the sub so that the edges of the sheet are behind the lip of the sub. Or you can design the cover sheet so that it forms a stand off and mount the grill on it.
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
cw383
Sep 30, 2015 12:41 AM
c_m_shooter
Sep 27, 2015 04:40 PM
ashalle2
Sep 27, 2015 03:28 PM
