Mounting sub boxes
Old Oct 7, 2006 | 10:23 PM
BlackLS's Avatar
Mounting sub boxes
I am planning on making a custom fiberglass sub box but I was wondering how everybody attached their boxes to their trunks. Any help or ideas would be greatly appreciated.
Old Oct 7, 2006 | 10:36 PM
senior_brown's Avatar
i;ve wanted to take the factory sub idea, pull it out, make 2 subs, one on each side, custom. i think thats how im gonna do it, it would save a lot of space that way
halfj99's Avatar
mine just sit...the bix is big enough/heavy enough to not move
Old Oct 8, 2006 | 02:50 AM
EmperorJJ1's Avatar
lol until you get in a wreck and that **** comes flying at your back at 60mph... oh and rips out the wires causing all kinds of sparks and electical arcs and ****... im going to bolt my **** down for a reason
Old Oct 8, 2006 | 04:12 PM
BlackLS's Avatar
And how are you planning to attach it
Old Oct 8, 2006 | 04:30 PM
vB00STw's Avatar
you could bolt it down from inside of the box and have a removable front incase you have to take it out
Old Oct 9, 2006 | 06:52 AM
EmperorJJ1's Avatar
lol i havent got that far yet since i dont have a set plan for the subs/amp rack (only had the car for a month so still doing ideas) anyway it all depends on the box to be honest... if its a tight fit you can bolt from the top and do something on the bottom (need to look at my trunk again to check on that) but i would use lag bolts if possible on L brakets.just always check if anythings in the way before you start bolting it down
Old Oct 9, 2006 | 08:42 PM
BlackLS's Avatar
Do you think attaching it to the piece of wood or whatever it is that covers the spare tire would hold it securely enough because I would still like to be able to access the spare and the battery.
Old Oct 10, 2006 | 06:49 AM
EmperorJJ1's Avatar
ya that would work... just use bolts rather then wood screws
Old Oct 10, 2006 | 10:09 PM
BlackLS's Avatar
Yeah I was planning on probbably using 3 or 4 bolts and just drilling the holes down through where the subs will be mounted so that you wont see the bolts and you'll just have to pull out the speakers if you ever need to unbolt it.
Old Oct 10, 2006 | 10:30 PM
BlueSS-supercharged's Avatar
bad idea, that cancels each other out opposing subs setup like that in that great of a distance would just hurt more.
Old Oct 11, 2006 | 04:22 AM
EmperorJJ1's Avatar
sounds good i was going to suggest that but there are many good wasy to bolt the box down so i decided not to
Old Oct 17, 2006 | 10:25 AM
SilverTurboRidin's Avatar
ACTUALLY i wouldnt use any bolts or screws. I dont believe in screwing in any other holes than the ones needed to seal the subs.
Have you tried velcro?? Like industrial velcro. Trust me...Few pieces of that it aint moving
Old Oct 21, 2006 | 10:26 AM
Badmunky's Avatar
I use a holder thing from semi battery boxes on most of my sub boxes. They can be unhooked in a few seconds to alow you to get to the spair and battery and hold the box in place vary well.
Later
Old Oct 21, 2006 | 10:51 AM
mesatrin's Avatar
If you are going to put holes in your box I would cover each with silicon or liquid nail after. Or, Bondoing the whole bottom of the box after the screws are in would work the best. This doesn't add to ease of removal though so it would have to be in a place you like it and never want to move it.
Old Oct 21, 2006 | 12:42 PM
EmperorJJ1's Avatar
you can glass it up but leave a good portion of the head out that way you can latch on still.
Old Oct 23, 2006 | 03:40 AM
Red06LS's Avatar
Thats been my dream since i got my car one 10 on each side, but if it doesnt work then on to plan 2.
Old Oct 23, 2006 | 03:43 AM
xspyder85x's Avatar
use the factory mounting point for the subwoofer. there is a little hole in the wall. thats what i used for my amp rack
ineedacobaltss
Nov 7, 2015 02:25 PM
OrangeCoba
Oct 1, 2015 10:00 PM
n20saturn
Sep 30, 2015 12:26 AM
c_m_shooter
Sep 27, 2015 04:40 PM
