My HU is being retarded
Everything was working perfectly til yesturday when I took out my batterys ground and added another ground wire, when I turned the car back on my voltage gauge and both amps powered up but the HU didn't light up at all and started beeping really fast for the first few seconds then stopped, I hit the reset button on the HU and now nothing powers up (HU, amps, voltage gauge)...I checked both fuses on the amp (1 fuse on red power wire, 1 glass fuse on yellow "back up" wire) both were replaced and I've checked the necessary fuses in the interior fuse box with no luck...
Anyone have any ideas? Thanks
I ended up taking out the 2nd ground cuz I thought that may be my problem
I've removed my ground like 100 times prior to this and never had a problem but I just recently had a alarm system put in but it dosent se like that would cause the radio to lock up and beep at me
I used to have an Eclipse.
That ESN is hit or miss sometimes.
Did You have to code it to a CD when you got it?
I def agree with the above post, it sounds like a typical Eclipse security issue. Whats the model #
It's the eclipse cd3200...
I honestly have no idea what to look for but damn I want this fixed soon having no music sucks
And btw I had circuit city install it and they are no longer in business but I never had to use any sort of cd
You want the good news or the bad news?
Your unit is either flashing because it wants you to code a CD for the security, or because it wants the coded CD that has been already made.
If you have the owners manual instructions to code a CD are on Pg 60. If not heres the link
http://www.eclipse-web.com/us/downlo...CD3200ae99.pdf
If CC coded it to a Cd without telling you then you will have to contact Eclipse and see what they can do for you, but there's way to say that they will 100% help you.
From what I've herd Eclipse /Fujitsu is not known for there customer service being all that good. In any case if it is coded it will most likely involve you sending the unit back to them for re-coding.
I feel for you bickloaf, to be honest I hope I'm wrong about it. But it sounds like what happened to me, however I had the CD I coded to the unit.
Remember it has to be a bought CD not a burnt one, and when your done put the damn thing in your sock drawer or something so you don't loose it
I don't think the HU is asking for a CD because it would not even let me open the face plate to put a cd in...while it does seem like a security issue it seems like it would have to be a blown fuse or something electrical since I was messing with the power supply at the time and I've never had problems with the security on the HU
lol ya not quite so bright... eclipse shut down all usa production so it might be a while if ever that you get a response. So i would yank it from the vehicle for now. Let the caps discharge then try putting it back in a day later. Eclipses are somewhat notorious for having crazy security. then again I've set it off on my kenwood a few times by disconnecting the batt or what not.
to some extent i hope its not a security issue otherwise you may be stuck. then again if it isn't i don't know what it could be so
also im still debating this windshield tint lol, esp since i got my inspection a month ago so i can get away with it for another year basically.
mine passed inspection with the windshield tinted but they bitched about my black lights and i had to buy new tail lights just for inspection...
windshield is just risky cause of police....a tinted windshield is ALOT more noticable than illegal side windows but it gives the car a whole new look
ill get some pics up once i get my side windows redone down to 15%
itll be dark as ****
anyways im gunna unplug everything from the back of the HU in a minute and let it sit for like a day
yea that got me too......the tinted taillights...i tried to argue with the guy since they were then stock lights "but look, it says dot sae here, i swear its how they came" but yea i dunno i just know it would overall make my car look alot darker considering i have 18% all round but that stupid tan dash that reflects light back in. yea let me know i gotta see that. anyways im out im tired as **** and have work at 5 and i just finished my struts and rims an hour ago.
